72914S
Jul 24 2004, 06:39 PM
Thanks for the idea!
Here are a couple of pix`s of the fit and finish. Only had to turn the viser pins (pointed end into the mirror).Having trouble with the pictures.I will try later if anyone is interested.
72914S
Jul 24 2004, 09:00 PM
Oh,
by the way I now have a couple of nice stock mirrors for sale .
kc4ixi
Jul 24 2004, 09:07 PM
Looks Great!
What model of BMW mirror did you use?
Was the holes for the pins the only modification you had to do?
Robert
72914S
Jul 24 2004, 09:27 PM
It was a mid 80`s .Had a square base with a spring and two pins under the base,had to remove that.(dremel with cutting wheel) Used viser holder as a template and drilled the two mounting holes and counter sunk.Also had to round the corners on the base.Then drilled the holes for the viser pins. painted the aluminium with satin black. Done in about two hours including drying time.
kc4ixi
Jul 24 2004, 09:40 PM
That awesome, I'll have to check into doing something like that.
Thanks for the information!
