Part number for this guage? |
cgnj |
Jul 25 2004, 12:36 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
Anyone have a part number for this guage? TIA, Carlos Attached image(s) |
MXMARK |
Jul 25 2004, 02:25 PM
Member Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
It looks like a 1974 911 combo. I think it is 91164110429 . The 1973 and older had a silver button in the middle and 1975 and newer had a temp range not numbers. I have been wrong before and will be wrong again , Mark
TRY THIS http://forums.pelicanparts.com/showthread....=oil+temp+gauge |
MXMARK |
Jul 25 2004, 02:39 PM
Pre 1974 maybe 1971 from my car.
skline |
Jul 25 2004, 02:43 PM
If you have the gauge in your hand, tip it back and look at the very top inside the glass and there will be the number along the rim.
Aaron Cox |
Jul 25 2004, 02:51 PM
mark. i am currently running the 914/6 gauge (gas/temp) but woul like to know how well your pressure gauge correlates to your /4 engine. lemme know.
Bleyseng |
Jul 25 2004, 03:17 PM
I am running a 911 combo gauge too, I think its out of a 72 911. You need the right pressure sensor for the gauge to be accurate, works great.
Gotta makeup a gas gauge thou which I did out of a oil temp gauge and the gas gauge parts. Then it fits into the center console like factory. Geoff |
MXMARK |
Jul 25 2004, 03:48 PM
Aaron, I have the 0-10 bar sender for the 0-10 bar gauge or the 0-140 psi gauge. The 0-5 bar goes to my 911 with the 0-5 bar gauge or the 0-70 psi. So the gauge is close. Use the vdo parts together. If I recall you have another brand sender in your case. The picture from above shows my car after driving to work while at idle with royal purple on a cool day. Mark
Bleyseng |
Jul 25 2004, 03:50 PM
found the pics...
Bleyseng |
Jul 25 2004, 03:52 PM
chart
Lo-Fi Version | Time is now: 11th May 2024 - 09:10 PM |
