cgnj
Jul 25 2004, 12:36 PM
Hi,
Anyone have a part number for this guage?
TIA,
Carlos
MXMARK
Jul 25 2004, 02:25 PM
It looks like a 1974 911 combo. I think it is 91164110429 . The 1973 and older had a silver button in the middle and 1975 and newer had a temp range not numbers. I have been wrong before and will be wrong again , Mark
TRY THIS
http://forums.pelicanparts.com/showthread....=oil+temp+gauge
MXMARK
Jul 25 2004, 02:39 PM
Pre 1974 maybe 1971 from my car.
skline
Jul 25 2004, 02:43 PM
If you have the gauge in your hand, tip it back and look at the very top inside the glass and there will be the number along the rim.
Aaron Cox
Jul 25 2004, 02:51 PM
mark. i am currently running the 914/6 gauge (gas/temp) but woul like to know how well your pressure gauge correlates to your /4 engine. lemme know.
Bleyseng
Jul 25 2004, 03:17 PM
I am running a 911 combo gauge too, I think its out of a 72 911. You need the right pressure sensor for the gauge to be accurate, works great.
Gotta makeup a gas gauge thou which I did out of a oil temp gauge and the gas gauge parts. Then it fits into the center console like factory.
Geoff
MXMARK
Jul 25 2004, 03:48 PM
Aaron, I have the 0-10 bar sender for the 0-10 bar gauge or the 0-140 psi gauge. The 0-5 bar goes to my 911 with the 0-5 bar gauge or the 0-70 psi. So the gauge is close. Use the vdo parts together. If I recall you have another brand sender in your case. The picture from above shows my car after driving to work while at idle with royal purple on a cool day. Mark
Bleyseng
Jul 25 2004, 03:50 PM
found the pics...
Bleyseng
Jul 25 2004, 03:52 PM
chart
