fs i have a large stock of quality 914 parts, make request, heres what i have, over 20 years collecting |
ripping914 |
Oct 12 2011, 06:30 PM
I'm new here ... Group: Retired Members Posts: 0 Joined: 4-October 11 Member No.: 13,644 Region Association: None |
here are some of the items i have, front bumpers,vintage black seats concourse, rear bumper rubber valance pad,gauge pods and gauges,wooden steering wheel,stainless steel heat exchangers 2.0, centre concil gauges,rear tailight lenses very nice,side shift transmissions, side shift linkages, front auxillary driving light grills, 1974 auxillary orange driving light switches,light switches,targa top seal nice,driver side outside mirrors, factory front windsheilds, steel lower front valances, fiberglass rocker panels,front and rear calipers,rear control arms, with good bearings cleaned and sprayed flat black, front strut towers, complete headlight assemblies, defrost blowers complete system, engine lid drain tray with proper funnels,steering rack covers,steering racks,front trunk floor pans to replace air condition removal with factory bolt down for spare tire,engine compartment relay covers, 2.0 ltr complete fuel injection systems, 2 of them, factory fuel pumps, front transverse arms cleaned checked prep painted flat black, front windsheild trim, sail panels,cut outs to replace outter door handle rot, floor pan sections for repairs, shifters, shifter knobs, fiberglass rear valance, relays,tail shift transmissions, tail shift linkage, i am listing these things like this because i dont want to jam the club with multiple adds, email me and i will send you photoes of what you want and give prices, i prefer pay pal, my pay pal adress is XXXXXXXXXX@XXXXXXX.com, i will accept all payment methods from club members, when it clears i will ship, can sombody let me know if the club participates in any charity or accepts donations for club purposes, i want to participate, thank you porsche 914 hunterbuilt,
Attached thumbnail(s) |
Tom_T |
Oct 12 2011, 06:42 PM
(IMG:style_emoticons/default/blink.gif) .... Whew! .... it might help if you made it into a list in your 1st post - instead of a very long running sentence. (IMG:style_emoticons/default/huh.gif)
A lot of us are old & can't read that well! (IMG:style_emoticons/default/biggrin.gif) Also, do a post in the Garage Forum & tell us about those fine P-cars, especially the 914 (make sure it's in your member info & the 914world VIN registry too). Then you'll no longer be listed here as a "Lurker" & have a post count started too (ads don't count)! (IMG:style_emoticons/default/biggrin.gif) It's a good idea to intro yourself there, and there is also a member vendors section here for your shop to list, as well as the banner ads you see at the top/bottom of the web pages (contact an Admin or SirAndy for the ads/rates/etc.) The classified rules state to list a price, but I don't know if a range of prices & OBO will qualify, but maybe one of the Admins can speak to that? Also your website in your member info area doesn't really go to anything: http://porsche.914.hunterbuilt.com Where are you in PA? Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
computers4kids |
Oct 12 2011, 08:30 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
This is from SchantzMD Hi there. Is this the guy in PA that was going under the eBay screen name, Screaming_914,... or something like that (I think he might of changed his eBay screen name to ripping*** something)? The only reason I ask is because I've had 2 separate people that have bought "Running Rebuilt low mileage" engines from him for ~$2500-$3000 respectively, and both had issues. I know this for a fact because one of this seller's engines I inspected and was able to get running, while the other one I tore down completely and declared DOA on arrival. The engine I got running for a fellow 914World member was said to of been a complete running 2.0L with EFI and 150 +/- a few psi compression across all 4 cylinders. After inspection it was found to have compression pressures of 115,120,80, & 150. This in itself was not a problem as the engine was used, but the issue came from the fact that the seller lied to the buyer telling him it was a very low mileage rebuilt unit that was pulled from a rusted out running car. The reality was that it was obviously some used long block that was slapped together with a bunch of parts that he had laying around,(including a junk flywheel and a distributor drive gear that was dropped in 180 degrees off). The second engine from this same seller was one that was dropped off at my shop. It was a complete 2.0L painted in red and silver and was setup with a single progressive carb. The engine was supposed to of been a very recent rebuild with a carbed cam that again was pulled from a "running car". After inspection the engine was found to have one dead cylinder, 2 with a 120 psi, and one with almost 190 psi. After a full dis-assembly I found that the engine had a junk stock cam and a crap load of fresh silicone on a bunch of used seals. The worst part of the engine was the compression issue and the reason for the varied #s was astounding! I found that the side of the motor with the 120 psi reading was due to the fact that someone had recently stacked 2 head gaskets on top of each other. The other side of the motor was even worse because it had no head gaskets at all and (1) flat top Euro piston, (the other 3 pistons were all low compression dished bus pistons). Both buyers also had the exact same experience as you with responses from this guy. When they contacted him about their concerns he humored them for a while and then basically told them to just F*** off. Feel free to re-post this on the World board if you'd like. If this is the Screaming_914 guy from eBay then I know from personal experience that he's a scammer and liar because I've seen his ads and then seen the actual product 1st hand. If so then I think he needs to explain why so many people are having issues if he's an "honest" seller, but if this is a different individual then I guess he's owed an apology. Mike |
somd914 |
Oct 13 2011, 03:49 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Looking for a decent front bumper for my 73, could you send pics of what you have?
ripping914 |
Oct 13 2011, 06:06 AM
Oct 13 2011, 06:12 AM
914-6 GT in waiting Group: Members Posts: 19,295 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Sent you a pm on the windshield. thanks, mark
abnrdo |
Oct 13 2011, 12:10 PM
Member Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
Looking for good chrome bumpers to backdate my 75.
abnrdo@yahoo.com Thanks, Jim |
76-914 |
Oct 13 2011, 12:19 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Sent you a PM re: steering wheel.
PBC914 |
Oct 13 2011, 12:57 PM
Member Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
Rear passenger lens needed-PM sent.
BarberDave |
Oct 13 2011, 01:03 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Console gauges, work ? pic ? shipping to 43567 any other console parts ,heat defrost lever ??? Dave (IMG:style_emoticons/default/slap.gif) |
loux951 |
Oct 13 2011, 01:14 PM
NOLA 914 Group: Members Posts: 35 Joined: 30-May 03 From: New Orleans, LA Member No.: 758 Region Association: South East States |
Looking for windshield and front bumper (not chrome) - PM sent...
t collins |
Oct 13 2011, 03:10 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
email request for rear targa trim sent
Thanks. Tom |
sdthomas |
Oct 13 2011, 03:17 PM
Member Group: Members Posts: 64 Joined: 14-June 11 From: Seattle Member No.: 13,193 Region Association: Pacific Northwest |
Interested in the side mirror. Could you post a picture?
sdthomas |
Oct 13 2011, 03:20 PM
Shift knob too.
yeakel1 |
Oct 13 2011, 04:55 PM
Newbie Group: Members Posts: 5 Joined: 15-July 10 From: Anaheim, CA Member No.: 11,943 Region Association: Southern California |
Sent PM on 2.0 SS HE and floor repair panels (IMG:style_emoticons/default/sawzall-smiley.gif)
ripping914 |
Oct 13 2011, 05:20 PM
could you please email me outside the club direct at ripping914@hotmail.com i dont want the clubs email to get logged down because of how i ran the add, out of respect for the other members, i will send you picts and prices thank you porsche914hunterbuilt
somd914 |
Oct 13 2011, 07:38 PM
Bob L. |
Oct 13 2011, 10:32 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
E-mail sent re: alternator back plate/wires.
hot_shoe914 |
Oct 13 2011, 10:54 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Could you post prices here please, per the rules, itmakesit alot easier for everybody.
mgphoto |
Oct 16 2011, 09:54 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
RIPPING IS THE IMPORTANT WORD HERE!
THIS GUY IS A THIEF DO NOT DEAL WITH HIM example: HELLO, I AM GOING TO GET RIGHT TO THE POINT, YOU ARE INSULTING MY INTELLIGENCE, I KNOW THIS MOTOR; YOU DONT KNOW SHIT, I DROVE THE CAR THIS MOTOR CAME OUT OF, IT RAN FINE, AND ALSO HAD GOOD COMPRESSION AND DID NOT SMOKE, THE PLUGS WERE WET; IS THAT A SUPRISE WHAT DO YOU DO WITHJ A MOTOR THAT WAS GOING TO BE PUT ION STORAGE FOR 3 MONTHS, YOU LUBE THE CYLINDERS, THIS MOTOR RUNS FINE, YOU SAY THE FLYWHEEL HAD END PLAY, WELL YOU COM[PLAINED ABOUT THE FLYWHEEL. SO YOU PROBALLY REMOVED IT AND DID NOT PUT THE SPACER SHIMS BACK IN, DO YOU KNOW HOW MANY IT TAKES ON A 914 DO YOU KNOW HOW TO MEASURE THE END PLAY,WELL I BUILT THJESE MOTORS FOR 20 YEARS, I DO KNOW, AND I CHECKED IT ALL OUT, THIS MOTOR IS EXACTLEY WHAT I SAID IT WAS, I DONT SELL JUNK, MY FEEDBACK SAYS IT ALL. YOU SAY ITS A CORE AND IS WORTH 700.00 ARE YOU OUT OF YOUR F----- MIND, GO FIND A GOOD SET OF THREE BOLT HEADS FOR THAT , GO FIND A FUEL IONJECTION SYSTEM FOR THAT, YOU MUST THINK I AM STARVING AND CARE ABOUT MY FEEDBACK OR EVEN PAY PAL,L YOU ARE TRYING TO USE THE SYSTEM IN PLACE FOR YPOUR BULLSHIT BENEFITS, YOU DID NOT EVEN GET THE MOTOR IN THE CAR, WHAT ARE YOU GOING TO SAY ABOUT THAT, WELL I PULLED A PLUG AND IT WAS FOWLED OUT, YOU WILL NOTY GET NOTHING FROM ME, I WAS HONEST ABOUT THE MOTOR, YOU ARE PLAYING CHILDISH GAMES WITH THE WRONG GUY, I CAN INSTALL THESE MOTOR IN 2 AND A HALF HOURS, I WAS HONEST AND MY ADD STATES NO RETURNS ACCEPTED AND THATS THE BOTTOM LINE, YOU EMAILED ME THE OTHER DAY COMPLANING ABOUT STUPID SHIT, I KNEW TODAY WAS COMING, YOU ARE TRYING TPO GET SOMTHING GOOD FOR NOTHING ITS WORTH 700.00 YOU ARE OUT IOF YOUR MIND, I WILL DO NOTHING FOR YOU, AS MY ADD STATES NO RETURNS, I HAVE BEEN AROUND FOR YEARS AND HAVE SEEN ALL THE GAMES. PEOPLE TRY TO ABUSE A SYSTEM, BY SAYING OH WELL IT IS NOT WHAT I WANTED OR I MIGHT TAKE SOME PARTS I NEED AND GET THE SELLER TO REFUND ME SOME MONEY SO I WILL COMPLAIN HE WILL GIVE IT TO ME BECAUSE OF FEEDBACK WELL YOU RAN INTO THE WRONG, GUY, I KNOW ALL THE GAMES PEOPLE PLAY, THATS WHY I DESCRIBE THE MOTOR AND GIVE NO RETURNS,QUIT BITCHING STOP TRYING TO BEAT THE SYSTEM AND PUT THE DAMN MOTOR IN YOU CAR AND DRIVE IT, DANNY HUNTER JJJ > To: a1partshunter@hotmail.com > F > Date: Tue, 14 Jun 2011 10:44:50 -0700 > > Hello Danny, > This engine has major problems! I pulled the spark plugs and they are > black and soaked with oil, either the rings are shot or the valve > guides are gone and the engine is running very rich. The crankshaft > has about 1/4 inch end play, meaning the main bearings are shot! > I don't think I can work with this engine as I expected it to going > into the car and be running in a few days, this need a total tear > down and rebuilt, this engine is a core and worth only about $700. > What can we do at this point? > Mike > > THIS A*HOLE IS CLAIMING NOT TO BE DANNY HUNTER, BUT HE IS USING HIS FATHERS NAME BECAUSE HIS IS SUCH DIRT!!!! DON'T GIVE HIM YOUR MONEY!!!! THIS IS WHAT HE SELLS. shorted alternator cooling fan broken fins JUST SOME OF THE CRAP HE SOLD ME CLAIMING IT WAS A 35K MILE ORIGINAL ENGINE |
Lo-Fi Version | Time is now: 27th May 2024 - 09:29 PM |
