Muellers VR6 swap project, running thread of a non-running motor :) |
mikerose |
Nov 16 2004, 09:56 AM
Happy to be back Group: Members Posts: 657 Joined: 31-December 02 From: Pittsburg,ca Member No.: 60 Region Association: None |
It runs right (IMG:style_emoticons/default/laugh.gif)
Andyrew |
Nov 16 2004, 11:14 AM
Ya!!!
Love it!!!! |
Chris914n6 |
Nov 18 2004, 11:28 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Looks like the water outlets will be a clearance problem with the trunk.
I don't know where I put my notes, but I think my Maxima V6 is a bit bigger on all dimensions. You're engine lid should not be a problem, you can cut the crossbar if really needed. I didn't need to. I'll have my engine out to do bay painting et al next month so if you need pics or ??? hit me up. I get to make a new upper intake manifold this winter... (IMG:style_emoticons/default/sad.gif) I'm trying really, really, hard not to put a turbo in at the same time (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) As useful as the fab'd upper rad inlet is with it's airbleeder, I sorta wish I used a 96ish Golf rad instead. A little taller at ~14 3/8" but sits flat on top so making a trunk divider would be easier & prettier. Oh, and don't put the water filler on the pressure side... no matter how well it sits in the bay. (IMG:style_emoticons/default/wacko.gif) Took a long time to figure that bugger out. (IMG:style_emoticons/default/headbang.gif) "Where, O, where is my hot water going??" Chris |
neo914-6 |
Nov 19 2004, 12:18 AM
QUOTE the wife does not know about it yet QUOTE oh yea...tan interior which goes well with the green.... Hey that looks like Patricks car we saw at his shop last weekend. Felix |
Chris914n6 |
Nov 21 2004, 02:43 AM
Ok, found my notes...
front to mounting face - 20" tranny overhang - 8" with 11" from top down top to bottom - 27.5" oil filter stuck out the front an extra 1.5" but I went with a remote filter. With the new manifold, tranny overhang will be about 3" which will keep it out of the trunk. Chris Attached image(s) |
Mueller |
Nov 21 2004, 02:36 PM
motor is in the car for test fitting (IMG:style_emoticons/default/smile.gif)
it's going to be tight, right now the transmission is moved about 1" to 1.5" forward....it looks like I'm going to have to modify the trunk wall a little to play it on the safe side... Attached image(s) |
Mueller |
asdf
Mueller |
Nov 21 2004, 02:37 PM
close fit firewall:
Mueller |
Nov 21 2004, 02:38 PM
tight/interferance rear trunk:
Mueller |
and last one
another view = tight/interferance rear trunk: Attached image(s) |
type47fan |
Nov 21 2004, 02:50 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Looks like the engine was made to go in there with minimal (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif)!!!
chunger |
Nov 21 2004, 02:52 PM
Member Group: Members Posts: 409 Joined: 11-January 03 From: Albany, CA Member No.: 133 |
sweet!
McMark |
Nov 21 2004, 03:06 PM
At least you got one motor installed today. (IMG:style_emoticons/default/biggrin.gif)
Jeroen |
Nov 21 2004, 05:58 PM
cool!!!
Mueller |
Nov 21 2004, 07:24 PM
did some more "fooling" around with the motor...it's not going to work without doing the following:
transmission=at the rear on the 2 "ears", mounts need to be relocated at least 1" lower and moved foward at least 2" firewall= needs to be modified by cutting or "massaged" with a BFH, one inch on the passanger side and about 2" on the drivers side (only the width of the motor)....I need to drop the oil pan and see if I can make it lower profile, if I can, i might not have to modify the firewall as much I knew the motor wouldn't just bolt in, but these mods are going to be a PITA, to make matters worse, my roll cage could be in the way on the drivers side depending on how much I need to modify the firewall (IMG:style_emoticons/default/headbang.gif) |
rick 918-S |
Nov 21 2004, 09:09 PM
Hey nice rack! -Celette Group: Members Posts: 20,457 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
IMHO, For what it's worth. Cut the trunk stuff and move the engine back.
Avoid cutting the passanger compartment firewall. You need to maintain some space where the cables come out of the lower bulkhead. I had some serious clearance issues with the cables. What's the oil pan made out of? If the motor is too low you could modify the pickup tube and cut the pan. |
Mueller |
Nov 22 2004, 12:54 AM
QUOTE(rick 918-S @ Nov 21 2004, 08:09 PM) IMHO, For what it's worth. Cut the trunk stuff and move the engine back. Avoid cutting the passanger compartment firewall. You need to maintain some space where the cables come out of the lower bulkhead. I had some serious clearance issues with the cables. What's the oil pan made out of? If the motor is too low you could modify the pickup tube and cut the pan. I cut the trunk wall and installed transmission in stock location..it's ugly, but not beyond being FUBAR'd I hope (IMG:style_emoticons/default/wacko.gif) targa top hits the motor when I tried to put it in the trunk and the rear trunk lid hits the top of the engine as well when I close the lid.. in the picture in this post, you'll see the red outlines for where I might have to "bump" the firewall, not too drastic and I do not have to touch the original engine shelf (I'm pretty sure) right now (no picture) there is about an inch of space on the drivers side between the firewall and the belt tensioner. On the passanger side, I have about 2" of space between the motor and the firewall. i'm going to make new transmission mounts and experiment with a few different sizes (I'll vary the amount transmission is lowered and moved forward.) The oil pan is steel, once I remove it and figure out how much I can shorten it, I'll do so (IMG:style_emoticons/default/welder.gif) on a side note, I told the wife of the engine conversion tonight, she was not impressed when I told her it'll have twice the power of the stock motor..her response?? "does not matter if it does not run" ouch !!!! ........i mentioned something about being the 1st person to do this swap, even while on the phone, I knew she was rolling her eyes while saying sarcasticly "oh great" (IMG:style_emoticons/default/laugh.gif) |
neo914-6 |
Nov 22 2004, 01:50 AM
Good thing you didn't use ProE (IMG:style_emoticons/default/laugh.gif) Don't feel bad we see it all the time at our company in the design phase of multimillion dollar equipment. At least these are mechanical hurdles which I'm sure you can solve. Electrical can be the real PITA.
Felix |
Mueller |
Nov 22 2004, 09:12 AM
QUOTE(Jaiderenegadesimpson V8 914 @ Nov 22 2004, 12:50 AM) Good thing you didn't use ProE (IMG:style_emoticons/default/laugh.gif) Don't feel bad we see it all the time at our company in the design phase of multimillion dollar equipment. At least these are mechanical hurdles which I'm sure you can solve. Electrical can be the real PITA. Felix I need to have my brain and tape measure re-calibrated (IMG:style_emoticons/default/smile.gif) I really thought it was going to fit better before I bought the adapter…oh well, time to make it work (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) |
Mueller |
Nov 22 2004, 10:42 PM
these pictures are with the transmission bolted to the stock location....plenty of space in front of the motor now.
Lo-Fi Version | Time is now: 15th May 2024 - 12:30 PM |
