Shrinking bearings with cold stuff |
sleepdoc |
Jul 27 2004, 02:57 PM
Newbie Group: Benefactors Posts: 24 Joined: 15-June 03 From: Pupakea, Oahu, HI Member No.: 826 |
Hi All,
I am working on replacing my rear wheel bearings and am about to put the new ones in. I want to shrink the bearing so it will slip in easily and have seen the great advice printed here on the board about freezing the parts. http://www.914world.com/bbs2/index.php?act...=ST&f=5&t=12197 My idea up for discussion is what about using lower temperatures to get a greater shrinking effect. I have access to both liquid nitrogen and dry ice. Both have long been used in this context: (quote ripped off a gas producer site) " Shrink fitting Cryogens such as Dry Ice, Liquid Carbon Dioxide, and Liquid Nitrogen can be used as low temperature refrigerants in shrink fitting of metal components. The process is rapid, effective and simple, and alleviates the possibility of damage of distortion through more traditional methods of force fitting, and metallurgical change caused by uneven or excessive local heating processes. By using cryogens it is possible to reduce the dimension of one component from that of another by thermal contraction. When immediately offered up and fitted to the other component, and left to warm up and expand again to room temperature, a tight interference precision fit will be generated. Cryogenic shrink fitting can also be used to dismantle assemblies. Shrink fitting can extend the life of roller bearings and other shaft fitted parts, as it maintains the interference fit for which the components were designed. When new bearings fail relatively quickly after installation, the chances are that although the bearing itself was sound, the improper installation cut short its life expectancy." Does anyone have any concern about negatively effecting the metals in this process? For instance most are familiar with freezing a super strong bike lock in liquid nitrogen and smashing the now brittle lock with a hammer. I am certainly not going to freeze my bearing in liguid nitrogen and smack it into the hub with a hammer! But lets say the thing slides right in and warms up in place, do you think the grease in the assembled bearing will be degraded by these very low temperatures? Or the plastic in the bearing cages changed, damaged? Or the metal does it become permanantly embrittled? Any machinists or metalurgists out there? What do you guys think? best Mark |
ArtechnikA |
Jul 27 2004, 03:07 PM
0F to -10F (freezer range) is enough.
dry ice if you must; i wouldn't need nitrogen. there's no need, and it's an unpleasant enough job without having to do it more often than necessary. 'course it's your car, do what you want ... |
balljoint |
Jul 27 2004, 04:33 PM
I just used the chest freezer in my garage. Worked fine. That cryo stuff sounds fun but it has to be expensive and may be better used to keep baseball heroes in stasis while their children fight over their money and DNA.
Joe Bob |
Jul 27 2004, 04:43 PM
Move Jimmy Hoffa over in the deeep freeze and plant the bearing on his chest....why complicate the issue.
mightyohm |
Jul 27 2004, 05:19 PM
Sounds like a cool idea to me. I wonder if the liquid nitrogen would actually alter the material properties of the bearing (like those cryogenic rotor guys claim). I wonder if there is any danger of creating cracks if you just dump the bearing in the LN2. I bet it would slip right in when you're done though!
Mueller |
Jul 27 2004, 05:40 PM
You could always contact the bearing manufacture (IMG:style_emoticons/default/smile.gif)
FAG bearings |
aircooledboy |
Jul 27 2004, 08:54 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
QUOTE(balljoint @ Jul 27 2004, 04:33 PM) That cryo stuff sounds fun but it has to be expensive and may be better used to keep baseball heroes in stasis while their children fight over their money and DNA. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/lol2.gif) (IMG:style_emoticons/default/chairfall.gif) |
mightyohm |
Jul 27 2004, 08:57 PM
Hey, if it's free, might as well give it a try. I have access to "free" LN2 as well.
Verruckt |
Jul 27 2004, 09:14 PM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
I used to work as a toolmaker. We used liquid nitrogen to shrink-fit parts all the time. The limited amount of time will have very little, to no effect on your parts. Other than shrinking them a few thousandths of an inch, just enough (hopefully) to get them in place. Most of the parts and fixtures we made were for the aircraft industry, and they have some bad@ss specifications. I would get any grease out of the way and make absolutely sure that there are no "foreign bits" in this space. Finding out that your new bearing is crooked while its warming up would not be 'fun'... (IMG:style_emoticons/default/unsure.gif)
scotty |
Jul 27 2004, 10:20 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
QUOTE I just used the chest freezer in my garage. Worked fine. I quite agree...although I enjoy playing with liquid nitrogen every year at school (IMG:style_emoticons/default/wink.gif) |
morph |
Jul 28 2004, 12:16 AM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
i just got my rear wheel bearings out of my freezer and tapped them in.love the basic laws of physics (IMG:style_emoticons/default/wink.gif).my wife hates parts in the freezer,drives her nuts if she sees them in there might need to get one of those little beer fridges just for me and my parts
lol |
ablose58 |
Jul 28 2004, 12:37 AM
rust never sleeps Group: Members Posts: 584 Joined: 6-December 03 From: port orchard,wa. Member No.: 1,422 |
Beer fridges are COOL (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/biggrin.gif)
Otmar |
Jul 28 2004, 12:44 AM
2000 Amps in a 914 Group: Members Posts: 174 Joined: 3-March 03 From: Corvallis, OR, USA Member No.: 387 |
AFAIK liquid nitrogen is best used for making ice cream at parties.
Good visuals and you get ice cream in about a minute. (IMG:style_emoticons/default/biggrin.gif) |
morph |
Jul 28 2004, 01:06 AM
alittle bit of trivia folks what two materials do the exsact opposite of all other materials when heated or cooled. there are only two. (IMG:style_emoticons/default/huh.gif)
crash914 |
Jul 28 2004, 05:32 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Hmmmmmm....I would say Ice(water), expands when frozen, and ?????Mercury?
crash914 |
Jul 28 2004, 05:33 AM
Oh yea!
Ice cream expands when frozen too..... |
ArtechnikA |
Jul 28 2004, 05:38 AM
QUOTE(morphenspectra @ Jul 27 2004, 11:06 PM) a little bit of trivia folks what two materials do the exact opposite of all other materials when heated or cooled. rubber has a negative coefficient of expansion, and contracts when heated ... water is most dense at 39F and expands when heated above or cooled below that. NiTinol does weird stuff with change of temperature, but that's an artificial effect... |
andys |
Jul 28 2004, 10:04 AM
QUOTE(ArtechnikA @ Jul 28 2004, 03:38 AM) rubber has a negative coefficient of expansion, and contracts when heated ... Huh? Can you post some evidence or a reference for this? Andy |
ArtechnikA |
Jul 28 2004, 10:16 AM
QUOTE(andys @ Jul 28 2004, 08:04 AM) ...Can you post some evidence or a reference for this? i wouldn't even begin to know where i packed my Chemical Rubber properties of materials handbook ... take a rubber band and suspend horizontally. between pushpins, for example. heat gently, as with a butane lighter; observe the phenomonon ... |
scotty |
Jul 28 2004, 10:25 AM
QUOTE (IMG:style_emoticons/default/biggrin.gif) my wife hates parts in the freezer (IMG:style_emoticons/default/biggrin.gif) Wait'll you see her reaction when you put parts in the oven (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 09:59 PM |
