Another Reason to Change out the Gas Lines, Wow! Close Calls |
bandjoey |
Oct 18 2011, 07:16 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
There's just no way to fix just one thing on a 914. While the motor was out I wanted to install the Tangerine steel fuel lines in the tunnel. Out comes the gas tank and what do I see but rubber gas lines about to come apart. Up front this probably wouldn't have caused a fire but ??????who knows. Actually the plastic lines in the tunnel looked pretty good, but who knows? Love the new ones!
Also, around the nipples nuts (now there's a conundrum if I ever saw one (IMG:style_emoticons/default/idea.gif) ) is black dried stuff like dried glue. Could this be just dried leaking gas or did the PO use some type of glue or sealer on the threads? Attached thumbnail(s) |
ldsgeek |
Oct 18 2011, 07:46 AM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
Is that 2 layers of fuel line in the second picture? Scary stuff there. Good luck.
TheCabinetmaker |
Oct 18 2011, 07:48 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
VaccaRabite |
Oct 18 2011, 07:53 AM
En Garde! Group: Admin Posts: 13,450 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
to expand on the "No"...
Fuel line is often made with fabric reinforcement. It helps keep the rubber together, adds burst resistance for pressurized applications, and add general strength to the line. Eventually the fuel line will separate and you get what you see above. Zach |
Cap'n Krusty |
Oct 18 2011, 07:58 AM
Note the "USA" printed on the hose, a clear sign that the hose wasn't the right inside diameter to begin with, and the slotted screw clamps used in an effort to force the fit. Bad news!
The Cap'n |
76-914 |
Oct 18 2011, 07:59 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I think that we shall see in the very near future just how often we NEED to change these hoses. Maybe the Cap't or someone that see these on a daily basis could make a recommendation as to change out intervals???
Cevan |
Oct 18 2011, 10:21 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I would also strongly recommend changing those clamps for real FI hose clamps. My local NAPA has them in metric sizes.
jmill |
Oct 18 2011, 10:25 AM
I pulled out my fuel tank last week. There was a gallon or so still in the tank. When I tilted the tank up both fuel lines ripped apart. It wasn't pretty. Thankfully I tilted it up enough to limit the spillage.
bandjoey |
Oct 18 2011, 10:54 AM
Is there a torque for the brass nuts holding the outlet tubes to the tank, or just armstrong tight?
7TPorsh |
Oct 18 2011, 11:03 AM
did you take the front hood off to pull the tank?
VaccaRabite |
Oct 18 2011, 11:06 AM
You do not need to pull the hood off.
Like many things, its easier if you do. Zach |
JmuRiz |
Oct 18 2011, 11:13 AM
914 Guru Group: Members Posts: 5,432 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'm going to change my lines when I do the 6-conversion. Going to do the same on my MB refurbish too...scary looking lines on that car.
sean_v8_914 |
Oct 18 2011, 12:34 PM
interval? I don't know but... CA and other states add ethanol. old school hose breaks down QUICKLY. buy hose rated to handle the new fuel formulation. to go cheap here could cost you a car later.
jt914-6 |
Oct 18 2011, 05:34 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
I've changed all the fuel lines to the ethanol resistant lines and used the FI clamps...Good you caught it in time Bill... (IMG:style_emoticons/default/beerchug.gif)
NOW....the rest of you need to do the same.....just sayin..... (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/shades.gif) |
bandjoey |
Oct 18 2011, 05:42 PM
It was a snap to pull the tank with the hood off. Bought new gasline and clamps from NAPA. The counter man said the life of the hose was less than 2 years unless I bought the new hose at $9 a foot that was alcohol resistant. Part salesman and part truth probably.
Hardest part was pulling up the new carpet to get to the inspection plates on the tunnel in installing the new Tangerine lines. Boy are they easy to install with the motor out. (IMG:style_emoticons/default/smash.gif) |
ChrisFoley |
Oct 18 2011, 06:03 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
It was a snap to pull the tank with the hood off. Bought new gasline and clamps from NAPA. The counter man said the life of the hose was less than 2 years unless I bought the new hose at $9 a foot that was alcohol resistant. Part salesman and part truth probably. He's not kidding about the lifespan of the cheap hose. It's less than 2 years in pressurized locations. OTOH, you shouldn't have to pay $9/ft for the good stuff. I sell it for considerably less than that. |
bigkensteele |
Oct 18 2011, 06:05 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I installed my SS lines this past weekend. Not as difficult as I had imagined. I pulled the return line first and was somewhat surprised that the plastic was still pretty pliable and seemed to be in good shape. When I pulled the supply line out, it cracked in two with very little lateral force. Glad that didn't happen while I was driving it!!!
That crap on your retaining nuts is old dried gas (varnish). It cleans off easily. Make sure that you really clean the tubes and the sealing surface on the tubes. You may want to use some fine sandpaper to get the sealing surface nice and smooth. Use new seals. I got everything I needed from Rotary'14 in the member vendors section including the above mentioned seals, clamps, etc., for what I consider to be crazy cheap. The lines are beautiful and fit perfectly. He even has an installation video on the post. Rotary Fuel Lines Good luck! (IMG:style_emoticons/default/beerchug.gif) |
RON S. |
Oct 20 2011, 05:55 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
interval? I don't know but... CA and other states add ethanol. old school hose breaks down QUICKLY. buy hose rated to handle the new fuel formulation. to go cheap here could cost you a car later. I recently converted all my fuel lines in my car from Aeroquip braided hose over to stainless hard lines. For the short flexible hoses on the end near the tank and such, you should ONLY use fuel line that is clearly marked SAE J30R9 along it's side. All fuel hose from any source is marked with an SAE rating on the side. Hose marked SAE J30R9 is the latest upgrade for fuel hose, and it is formulated to withstand E85 ethanol, foul gas and the like. This is also a fuel injection rated hose so it's good for 100psi+ Figure the hose to be sold at the auto parts stores for 6-10.00 a foot. There is some hose out there with J30R7 markings, and this is an older hose. Not as good as the R9. Just an FYI Ron |
sean_v8_914 |
Oct 20 2011, 07:11 PM
thanks for posting the spec
Black22 |
Oct 20 2011, 07:16 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I picked up the 30R9 hose from Pep Boys for $4.99 p/ft.
Lo-Fi Version | Time is now: 28th May 2024 - 03:18 PM |
