Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
I am about to remove tranny to replace input shaft seal. I recall reading here or somewhere that gear oil can also escape from the pivot bolt. What should I do to seal it if I find it has been weeping?
Is there a seal or O ring of some sort? Or do I use RTV? |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
I used black RTV. If you have at least a few threads holding it in it should be ok.
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,707 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
I've had good luck using blue Loctite
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Leaks from this area are most often caused by people putting too many shims/washers under the pivot ball in an attempt to compensate for an out of spec flywheel. The more you cut the flywheel to reuse it, the more you need to move the pivot forward to compensate for the removed material. If this is the case, remove all the shims and get a new flywheel. They're expensive.
Lo-Fi Version | Time is now: 30th July 2025 - 02:25 PM |
