Fuel pump and filter alternative mounting for carbs, first mock up complete |
moparrob |
Oct 24 2011, 09:38 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
I just got through my first attempt at mounting a new fuel system to supply my Weber 40IDA3C carbed 3.0 liter engine. I wanted to try to run the system in hard line - part for looks part for the challenge and learning experience.
These are the components I started with: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1319513899.1.jpg) I am using 3/8 aluminum line with anodized -AN 6 fittings throughout. Here is the view with the spare tire removed: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1319513899.2.jpg) You can see it is pretty tight behind the tire: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1319513899.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1319513899.4.jpg) This is the view with the tire installed: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1319513899.5.jpg) So far so good. Now to run the line to the rear and install the pressure regulator. To be continued.... |
Lo-Fi Version | Time is now: 29th May 2024 - 08:45 PM |
