I just got through my first attempt at mounting a new fuel system to supply my Weber 40IDA3C carbed 3.0 liter engine. I wanted to try to run the system in hard line - part for looks part for the challenge and learning experience.
These are the components I started with:
I am using 3/8 aluminum line with anodized -AN 6 fittings throughout. Here is the view with the spare tire removed:
You can see it is pretty tight behind the tire:
This is the view with the tire installed:
So far so good. Now to run the line to the rear and install the pressure regulator.
To be continued....
