Rear sway bar hanging detached, Hook it up or pull it out? |
ammason |
Oct 28 2011, 05:06 PM
Member Group: Members Posts: 88 Joined: 14-March 05 From: Sunny Honolulu Member No.: 3,758 Region Association: Hawaii |
Hey all - my new little 75 has a rear anti-roll bar but is missing the linkage connecting it to the trailing arms. When running stiff springs I seem to remember lots of folks pulling the rear off, but I want to know what my best option is with a stock setup. Is it unwise to run around with it detached? Should I spend time / $ putting the linkage back in there? Should I just pull it out and forget about it? She seems to handle just fine as-is....
ArtechnikA |
Oct 28 2011, 05:45 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
if you have no front bar, I wouldn't run a rear bar.
unless you're some kinda pro-rallye god who loves full-lock oversteer on a regular basis... |
914werke |
Oct 28 2011, 05:49 PM
"I got blisters on me fingers" Group: Members Posts: 10,081 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Pull it off & send it to me (IMG:style_emoticons/default/happy11.gif)
jcambo7 |
Oct 28 2011, 08:42 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
Heck. If you want one than you can have mine. Off a 73 with everything for it. |
shoguneagle |
Oct 28 2011, 10:02 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Maybe the question should be: Do I have a limited slip differential? Do I need a rear sway bar?
I have a rear sway bar without a limited slip diff and disconnected it because I did not like the way it affected handling in a corner. That is my two cents!! |
914werke |
Oct 28 2011, 11:12 PM
Heck. If you want one than you can have mine. Off a 73 with everything for it. (IMG:style_emoticons/default/idea.gif) |
ConeDodger |
Oct 29 2011, 02:00 PM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have one on mine and I have it hooked up. I disconnect for track days and have it connected for ax and street driving. It's really driver feel. I have a torque. Biasing differential and like the way it handles with it. Just don't want the rear coming around on me at the track...
Lo-Fi Version | Time is now: 20th May 2024 - 04:17 PM |
