74 gt flared roller for sale (sold) |
mrdkrantz |
Oct 30 2011, 12:21 PM
Newbie Group: Members Posts: 35 Joined: 28-December 10 From: Eastern Shore MD Member No.: 12,532 Region Association: North East States |
Selling my 1974 914.
Basic specs: -glass flares -glass nose -Raised letter rockers -Ats wheels new tires -clean interior -fairly clean all over -Had a 1911cc motor with dellortos (not being sold with) What it needs to be complete: -Motor old not worth it -new pass side engine shelf I cut it out to replace -patch rust on pass engine mount needs a patch made and welded in -patch rust on inner rear fender by battery i rivited pieces in but it should be done right. it was a temp thing while i was still driving it -finish fuel system fuel tank pulled cleaned up filter and pump mounted in front trunk aluminum line run through tunnel Rusty areas -rear trunk(surface) -pass engine mount (need a patch) -inner pass rear fender by engine (needs patch) -pass engine shelf (need new piece) I bought the car in 2000 and used it as my first car. I put the flares on had it painted etc. In the past year it has sat with no motor in it and I have been slowly working on it. ( I pulled the motor because it never sat its rings properly tore up the piston/cylinder etc. I already sold the dellorto carbs that were on it) I redid the interior a bit. Removed the tar floor stuff primed and painted it. Repaired the inner pass rocker. and other stuff. I am just tired of working on it and lost interest. I have the transaxle and and full stainless heat exchangers, good original front bumper with pad and Im sure other stuff if I dig. let me know $1500 for all located in Salisbury, MD Dale |
Lo-Fi Version | Time is now: 18th May 2024 - 02:10 PM |
