Selling my 1974 914.
Basic specs:
-glass flares
-glass nose
-Raised letter rockers
-Ats wheels new tires
-clean interior
-fairly clean all over
-Had a 1911cc motor with dellortos (not being sold with)
What it needs to be complete:
-Motor
old not worth it
-new pass side engine shelf
I cut it out to replace
-patch rust on pass engine mount
needs a patch made and welded in
-patch rust on inner rear fender by battery
i rivited pieces in but it should be done right.
it was a temp thing while i was still driving it
-finish fuel system
fuel tank pulled cleaned up
filter and pump mounted in front trunk
aluminum line run through tunnel
Rusty areas
-rear trunk(surface)
-pass engine mount (need a patch)
-inner pass rear fender by engine (needs patch)
-pass engine shelf (need new piece)
I bought the car in 2000 and used it as my first car. I put the flares on had it painted etc. In the past year it has sat with no motor in it and I have been slowly working on it. ( I pulled the motor because it never sat its rings properly tore up the piston/cylinder etc. I already sold the dellorto carbs that were on it) I redid the interior a bit. Removed the tar floor stuff primed and painted it. Repaired the inner pass rocker. and other stuff. I am just tired of working on it and lost interest. I have the transaxle and and full stainless heat exchangers, good original front bumper with pad and Im sure other stuff if I dig.
let me know $1500 for all
located in Salisbury, MD
Dale
