> what size socket do I need to remove oil sandwich adapter?
mightyohm
post Oct 30 2011, 01:43 PM
I'm trying to remove a Mocal sandwich adapter (with thermostat) and I can't find a socket that fits the threaded piece in the middle that holds the adapter on. It's big - somewhere around 27-30mm. Anyone know off the top of their head what size it is (or is it even metric)?
Hopefully going to stop by my FLAPS today to pick up a socket.
mightyohm
post Oct 30 2011, 05:01 PM
Figured it out - the threaded collar can be removed with a 1 1/8" deep socket (I don't think there is a metric equivalent).
McMark
post Oct 30 2011, 07:43 PM
914 Freak!
914Mike
post Oct 30 2011, 11:18 PM
QUOTE(mightyohm @ Oct 30 2011, 04:01 PM) *
That is what I use. Don't have it out to measure, but 1 1/8" is over 28.5mm, so it could be a 28mm if the inch socket was kinda loose.
rwilner
post Oct 31 2011, 09:22 AM
No Ghosts in the Machine
Jeff just curious -- why are you removing it?
I have the same unit on my car and it seems to work great. Is there something I should know?
pcar916
post Oct 31 2011, 09:36 AM
Is that a Lola?
QUOTE(914Mike @ Oct 31 2011, 12:18 AM) *
... 28mm if the inch socket was kinda loose.
Yeah, like a 12pt rather than a 6pt, thin sidewalls, and flat on the end.
1. The hex portion of the fitting is usually darned shallow and the tapered inner-edges of a socket only allows a little of it to grab the fitting.
2. If the socket is a thick-walled one the recess in the sandwich adapter might be too small and prevent the socket from going all the way down onto the fitting.
- Lo-Fi Version Time is now: 3rd March 2026 - 12:04 AM
