what size socket do I need to remove oil sandwich adapter? |
mightyohm |
Oct 30 2011, 01:43 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I'm trying to remove a Mocal sandwich adapter (with thermostat) and I can't find a socket that fits the threaded piece in the middle that holds the adapter on. It's big - somewhere around 27-30mm. Anyone know off the top of their head what size it is (or is it even metric)?
Hopefully going to stop by my FLAPS today to pick up a socket. |
mightyohm |
Oct 30 2011, 05:01 PM
Figured it out - the threaded collar can be removed with a 1 1/8" deep socket (I don't think there is a metric equivalent).
McMark |
Oct 30 2011, 07:43 PM
914Mike |
Oct 30 2011, 11:18 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
rwilner |
Oct 31 2011, 09:22 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Jeff just curious -- why are you removing it?
I have the same unit on my car and it seems to work great. Is there something I should know? |
pcar916 |
Oct 31 2011, 09:36 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
... 28mm if the inch socket was kinda loose. Yeah, like a 12pt rather than a 6pt, thin sidewalls, and flat on the end. 1. The hex portion of the fitting is usually darned shallow and the tapered inner-edges of a socket only allows a little of it to grab the fitting. 2. If the socket is a thick-walled one the recess in the sandwich adapter might be too small and prevent the socket from going all the way down onto the fitting. |
Lo-Fi Version | Time is now: 20th May 2024 - 03:22 PM |
