964 Clutch WORKS!, 964hydro cl.on a 914 pedal assy |
RON S. |
Aug 3 2004, 04:52 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Got my clutch unit fully working now.
The master cylinder is a 964 unit I picked up at Hershey this year for 50 bucks. The slave cylinder is a Wilwood unit I got from Jeg's a couple weeks a go. It was a good bit of work,but the total outlay of $$$cash was only about $200.00 dollars. Only thing left is to finalize the trunnion design on the clutch arm.I'll probably do something in brass. Here's a few w/pics. Ron Attached image(s) |
RON S. |
Aug 3 2004, 04:53 AM
next pic
Attached image(s) |
RON S. |
Aug 3 2004, 04:55 AM
One more,
Reservoir is a Ford Ranger pice lifted from a junkyard. (pocket item) Ron Attached image(s) |
machina |
Aug 3 2004, 04:57 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
beautiful work ron,
are those big AN lines in the footwell oil lines? your feet must get hot. let us know how well it works on the track. dr |
Brad Roberts |
Aug 3 2004, 08:06 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The rear "strap" you have on the slave wont work for more than a weeks worth of driving. It needs to be beefy. I would imagine if you put somebody in the car to bleed the clutch while you where underneath you would easily see the flexing that will occur.
Done a few of these... I do however like your front setup. I think it is physically more work than mounting one in front of the clutch arm... but it doesnt appear that you had to weld anything. B |
East coaster |
Aug 3 2004, 12:11 PM
Senior Member Group: Members Posts: 1,673 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Is there no concern with cutting the chunk out of the center tunnel to make room for the master cyl???
The setup looks good Ron, I can't wait to hear your impression of the car when you get it going!! I'm sure it'll get me inspired to get back on my project. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:50 AM |
