Shudder on accelleration, Clutch ? Timing ? |
2-OH! |
Aug 4 2004, 01:40 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
1976 - 2.0
Just got the car back together, new clutch plate, pressure plate, T/O bearing, flywheel, terry cable, bushings and engine re-build...Pedal play is 1/2 to 3/4 inch... When I shift, I get momentary shudder in all gears (more pronounced in 1st, 2nd, lees in 3rd, less in 4th hardly noticeable in 5th) and the car lacks all it's power... Valves are adjusted correctly, F/I seems to be correct, no vacuum leaks that I can find... Any thoughts ??? 2-OH! |
Lo-Fi Version | Time is now: 26th May 2024 - 06:08 PM |
