turn signal switch rebuild |
basenji7 |
Aug 4 2004, 09:15 PM
Newbie Group: Members Posts: 21 Joined: 20-April 04 From: dallas, tx Member No.: 1,953 |
I had my turn signal/light switch out and a piece fell out. Does anyone have any idea where this piece fits back in?
Thanks, darryl Attached image(s) |
JoeSharpOld |
Aug 4 2004, 10:09 PM
Does it seem cold to you Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 |
Darryl: I just had one of those in my hands and I have no pictures, but check this out. The hole in it gose through one of the screws that hold the switch to the steering colum body, the tab( that you can see in the picture just below the hole) will insert into the plastic body of either the wipper or trun signal switches. Theres only 8 ways it can go on.
Good Luck. Joe |
basenji7 |
Aug 4 2004, 11:38 PM
Joe,
Each one of those four screws have a collar in there. The collars never came out of place. i was working the levers and it seamed like it popped out from the inside. I think i understand what u r saying but i don't c how that could be bcuz of the collars. it would have never been able to fit in through the path of those 4 screws unless it was at the very top by the head of the screw or on the opposite end. am i missing something??? thanks.... darryl |
SLITS |
Aug 4 2004, 11:48 PM
If it comes apart, innumerable small springs and copper contacts come out. Don't even try to repair it. When they put it together there is a snap tab that holds the assembly together - Once broken, it's finished ( I spent three hours trying to get one back together).
I haven't seen the objects you imaged in any of the assemblies - but I could take one apart for the fun of it . Tell me which one it is - I have used spares and will send one to you. |
basenji7 |
Aug 5 2004, 12:17 AM
Slits,
it's a '74 2.0L and the number on the back of 1 of the switches is SWF HLS 71 SAE QB 71 thx....darryl..... Attached image(s) |
gklinger |
Aug 5 2004, 10:57 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
Had the same thing happen to me. Consensus at the time was don't worry about it. So I didn't - put it back together without it - and everything's been fine. YMMV (IMG:style_emoticons/default/confused24.gif)
http://www.914world.com/bbs2/index.php?act...&hl=turn+signal |
Joe Ricard |
Aug 5 2004, 11:00 AM
I'm going to take a stab at it. I believe this is the lug for the horn lead. Brown and white wire that strings up the column.
Aug 5 2004, 12:21 PM
QUOTE(Joe Ricard @ Aug 5 2004, 09:00 AM) I'm going to take a stab at it. I believe this is the lug for the horn lead. Not on a 74.... The 72+ (I think!) ones connect directly to a ring on the back of the horn button. No idea what the part is, though. --DD |
914werke |
Aug 5 2004, 04:15 PM
"I got blisters on me fingers" Group: Members Posts: 10,040 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
If Im correct it the actuates the auto cancel.
The same thing happend to mine (73) and I didnt notice any change till later. R. turns w/signal auto-cancels L. not. (or visa-versa) What about the upgrade to the 924 stalk with the electric washer pump option? Or is that the wrong stalk? |
sfrenck |
May 27 2013, 01:45 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Jmedeiros |
May 27 2013, 01:51 PM
Member Group: Members Posts: 99 Joined: 12-November 12 From: Los Banos, CA Member No.: 15,138 Region Association: Northern California |
Looks like it provides ground.
Bartlett 914 |
May 27 2013, 05:16 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Without that ground making good connection, The wiper sometimes will wipe intermittently
Lo-Fi Version | Time is now: 4th May 2024 - 08:29 PM |
