Price Check Aisle 9, 2.0 F.I |
bulitt |
Nov 7 2011, 06:35 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Next yr. will be selling a 1973 2.0 f.i engine with tins, computer and everything bolted to it. no heat exchangers. Keeping the trans.
Runs good but have no records of service or overhaul. What would be a good price range? Thanks! |
jimkelly |
Nov 7 2011, 08:01 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
you should do a compression test as most will ask this. if all cylinders are at about 125 psi and engine has none to minimal oil leakage and no pulled exhaust studs - i'll guess a decent asking price with FI is between $1000-$1500 ??? just having heads work to rebuild an engine can run this amount.
SD914 |
Nov 7 2011, 09:54 PM
SD914 Group: Members Posts: 55 Joined: 18-November 07 From: San Diego Member No.: 8,351 Region Association: Southern California |
Next yr. will be selling a 1973 2.0 f.i engine with tins, computer and everything bolted to it. no heat exchangers. Keeping the trans. Runs good but have no records of service or overhaul. What would be a good price range? Thanks! Also consider that a 2.0 is a commodity and the most desired of all the engines. If the compression is @ 125 or above i would insist on no less than $1500. Make sure and clean it up because a little grease cleaner and paint on the tins can make for a faster sale. Mike |
914ltd |
Nov 8 2011, 07:29 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
I agree with Jim and Mike, You have all the components to replace any engine, any year without having to buy anything but gaskets. Exhaust systems will bolt up to any 4 cylinder engine. This would be a great replacement for a tired 1.7 or 1.8 and would be far cheaper and likely better results than a rebuild. These are not terribly difficult engines to rebuild but the majority of "rebuilt engines" I have had brought to my shop are a mess.
Good runner with no exhaust stud or port problems other possible problems checked, $1500. minimum. Good luck, Brad |
bulitt |
Nov 8 2011, 01:48 PM
Thanks Guys!
Lo-Fi Version | Time is now: 17th May 2024 - 08:59 PM |
