> mysterious loop, how to get rid of it?
machina
post Aug 5 2004, 03:04 PM
I can't remember what this was for, maybe the hatch springs. I want to remove it to mount the regulator.
Can I use a chisel between it and the body? I don't want to massacre the engine bay.
thanks,
dr
Joe Ricard
post Aug 5 2004, 03:07 PM
CUMONIWANNARACEU
Yup that is what it is for. Drill the welds out and it should fall right off. Chisels and hammer will really screw it up.
machina
post Aug 5 2004, 03:11 PM
Thats going to be alot of holes in my newly painted trunk. (IMG:style_emoticons/default/sad.gif)
Maybe I can just cut it off an leave the small plates in place.
dr
post Aug 5 2004, 03:16 PM
Resident German
QUOTE(synthesisdv @ Aug 5 2004, 02:11 PM)
when he said "drill the weld out" he meant using a spot-weld drill bit. (IMG:style_emoticons/default/wink.gif)
no holes. take a cutoff wheel to the *hoop* and cut it out, then use a spotweld drill bit on the spotwelds.
should come right off without holes in the trunk.
(IMG:style_emoticons/default/smash.gif) Andy
Dave_Darling
914 Idiot
Drill the spot-welds, or take an angle-grinder to the loop. You'll need to touch up the bare metal parts regardless of how you remove it.
--DD
machina
post Aug 5 2004, 03:21 PM
QUOTE(SirAndy @ Aug 5 2004, 05:16 PM)
OK, I get it now. (IMG:style_emoticons/default/idea.gif)
I was going to put the regulator and fuel lines at the forward bulkhead but then I realized that the carbs are much closer to the rear bulkhead. Will keep all the fuel lines nice and tidy to the rear of the bay.
dr
- Lo-Fi Version Time is now: 12th July 2025 - 02:20 AM
