Did a search, found no info.., rear caliper rebuild kits...HELP!! |
SpecialK |
Aug 6 2004, 05:31 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Does anyone know of a place to get complete rear caliper rebuild kits? I'm getting a blister on my index finger from clicking through sites only to find that they only sell partial kits. (IMG:style_emoticons/default/headbang.gif) My rears need a complete make-over, leaking out of everywhere.
Thanks in advance! Kevin |
lapuwali |
Aug 6 2004, 06:51 PM
Pelican sells a kit with all of the seals in it.
McMark |
Aug 6 2004, 07:08 PM
Including the e-brake parts? (IMG:style_emoticons/default/idea.gif)
SpecialK |
Aug 7 2004, 02:28 AM
Pelican was my first choice, but there kits only contain the boots and piston seals (as far as I can tell by their discription). I need the halve seals and adjusting screw seals included. The ones I got for my '73 I got from GPR a couple of years ago they had everything, but appearantly they don't list the rear kits on their site anymore. Mittlemotor's site won't come up, something wrong?
IronHillRestorations |
Aug 7 2004, 07:59 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've got em. Send me a pm or e-mail me at: a914man@netease.net
PK (IMG:style_emoticons/default/cool.gif) 914 Network |
lapuwali |
Aug 7 2004, 09:02 AM
Pelican's kit is complete. The description is bad, I'll admit. All of the seals were there when I bought them to repair a leak at the e-brake arm. Note that this leak is actually caused by a failed O-ring in the inboard adjuster. There are no seals at the e-brake arm itself. This kit also included the seals between the caliper halves.
McMark |
Aug 7 2004, 10:34 AM
If there are no seals for the e-brake arm, it doesn't sound very complete.
Aug 7 2004, 12:47 PM
QUOTE(markd@mac.com @ Aug 7 2004, 08:34 AM) If there are no seals for the e-brake arm, it doesn't sound very complete. I don't know if any of the caliper rebuild kits contain seals for the parking brake lever. I don't believe it is inside the pressure curcuit anyway. PK (IMG:style_emoticons/default/cool.gif) |
lapuwali |
Aug 7 2004, 07:01 PM
Yeah, when I said there are no seals at the e-brake arm, I meant there are no seals IN THE CALIPER. The only seal on that side of the caliper is the O-ring on the inboard adjuster shaft. That's the seal that lets go and causes a leak that appears to be coming from the e-brake arm. If that adjuster O-ring is intact, there shouldn't be any brake fluid anywhere near the e-brake arm itself.
A complete kit only needs the adjuster O-rings, the flat O-rings between the caliper halves, the piston seals, and the piston bellows. Some kits also seem to include the snap rings that hold the bellows in place. The tech article on Pelican mentions removing a plug above the e-brake arm, but I can't imagine why that would be necessary unless the e-brake arm itself is broken. |
McMark |
Aug 7 2004, 10:13 PM
I have a line on COMPLETE ebrake rebuild kits. When you pull the ebrake lever shaft out of the caliper there is a seal right there. On the spring side. My source has kits that include these seals. I know the one on my caliper is leaking.
gregrobbins |
Aug 7 2004, 11:42 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Mark, what is your source? And what is the cost.
Anyone else had a e-brake seal problem? How likely is it to go bad and need replacing? |
lapuwali |
Aug 8 2004, 08:54 AM
Mark, are you talking /4 or /6 rear calipers?
When I rebuilt my /4 rear calipers a couple of months ago, there was no seal on the e-brake arm. The one on the inboard adjuster was leaking, and fluid was pouring out of the e-brake arm area. Replacing the seal on the adjuster fixed the leak. This was on an early car ('71). As far as I could tell, the calipers had never been rebuilt before. Unless the later or /6 rear calipers are very different, I can't see what a seal on the e-brake arm would be for, except perhaps as a shield to keep dirt/water OUT of the e-brake mechanism. |
Lo-Fi Version | Time is now: 10th May 2024 - 01:03 AM |
