| Andyrew |
Aug 7 2004, 12:33 AM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
So.... Brad, you said that a 914 starter just wont do it... Ok..
All you v8 guys.. What are you running starter wise? 911? (will it bolt right up?) High tq, lightweight starter? Other? Danke Andrew |
Andyrew V8 starter... Aug 7 2004, 12:33 AM
SLITS I don't own a V8 914, but get one of the ... Aug 7 2004, 12:39 AM
Andyrew Will a 911 starter work?
I can buy a 911 starter ... Aug 7 2004, 12:47 AM
skline I am running a High torque gear reduction starter ... Aug 7 2004, 01:14 AM
Andyrew I know, I know.... but someone currently just stat... Aug 7 2004, 01:22 AM
ArtechnikA there are at least two early 911 starters - the ... Aug 7 2004, 04:55 AM
Andyrew What about the later starters? Will they work?
Im... Aug 7 2004, 09:33 AM
neo914-6 Andrew,
Try this guy for used conversion parts Wre... Aug 7 2004, 01:30 PM
Andyrew I've got everything... (well, once I scamper o... Aug 7 2004, 02:31 PM
SLITS Use the 1.2 kW 911 starter. The stock starter is ... Aug 7 2004, 03:14 PM
Andyrew Aight, I'll do a search for the info.
Thanks ... Aug 7 2004, 03:21 PM
bryanthompson I don't know if this will help you or not:
htt... Aug 7 2004, 03:27 PM
Andyrew Thanks for the link! Just what I needed to see... Aug 7 2004, 09:18 PM
johnelliott Kennedy makes one that works, but they (the owner ... Aug 8 2004, 02:25 PM
mayord2001 A 911 starter will work for several weeks to a few... Aug 9 2004, 03:10 PM
datapace I agree about the gear reduction starter. Used a ... Aug 9 2004, 04:36 PM
rick 918-S My 928 motor has 10:1 compression. 911 starter spi... Aug 9 2004, 08:33 PM
ArtechnikA
Brad Roberts His 911 starter will start it fine. I know of at l... Aug 9 2004, 11:12 PM
Andyrew Sooo.... Brad.....
How much?
:D
I wana buy so... Aug 10 2004, 01:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:22 AM |
