heat exchanger, a.k.a. header? |
opera guy |
Aug 7 2004, 05:00 AM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
Regarding the part known as "Heat Exchanger," does that include the exhaust manifold (header)?
Can the heat exchanger be bought without buying the header? i see quite a number of the people here mention Stainless Steel heat exchangers, but its never referred to as header or exhaust manifold, why? just porsche lingo? conversely, when you buy SS heat exchanger, are you getting the header portion as well? Since i need both parts (if they are indeed separate) are there OEM or aftermarket ones available? if so, where is the best source (Pelican's out) or am i stuck with getting hand-me-downs? (not that there's anything wrong with it) this is for a 73 2.0, btw, thanks in advance |
Rusty |
Aug 7 2004, 05:53 AM
Hey Opera Dude (IMG:style_emoticons/default/smile.gif)
Headers are a set of pipes between the exhaust ports of the engine and the muffler. Heat exchangers ARE headers, with boxes built (permanently, they do not disassemble) around them to guide air around the headers, help warm that air up, and then direct it into the passenger compartment so we have heat. (IMG:style_emoticons/default/smile.gif) Headers = exhaust with no heat Heat exchangers = exhaust with heat When I first got into 914s, I was confused about the terminology, too. (IMG:style_emoticons/default/smile.gif) Hope this helps, Rusty (IMG:style_emoticons/default/smoke.gif) |
opera guy |
Aug 7 2004, 06:30 AM
thanks for clearing this up for me.
Performance Products (the "other" pp) has it for $39 (IMG:style_emoticons/default/blink.gif) must be a typo, here's a pic and link http://www.performanceproducts.com/Product...&producttype=20 |
opera guy |
Aug 7 2004, 06:31 AM
duh, forgot pix
watsonrx13 |
Aug 7 2004, 06:44 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Hey Opera Dude, you might want to check the item again, it is the SS heat exchanger BRACKET, not the heater/header that you thought.
The add's description is 'Bracket (Bolts To Rear Tran Case, 1 Required) '. But you were right, it was too good to be true. (IMG:style_emoticons/default/smoke.gif) |
opera guy |
Aug 7 2004, 07:02 AM
where does it say "bracket" on their site?
rhodyguy |
Aug 7 2004, 07:59 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what a f-ed up ad. i read that as he's for $39.95 also. plus those are not 2 liter ones. note the tall kick up on the muffler end. if you had a 1.7/1.8 exhaust setup you would be dissapointed. i would buy he's at that price all day long for resale.
kevin |
Allan |
Aug 7 2004, 08:43 AM
Look around on the 914 related BBS's. I found a nice clean used set of 2.0 SS HE's for a hundred from a guy in Canada. (IMG:style_emoticons/default/boldblue.gif)
rhodyguy |
Aug 7 2004, 08:50 AM
a set for a c-note was a great buy.
Lo-Fi Version | Time is now: 12th May 2024 - 04:38 PM |
