| tradisrad |
Nov 14 2011, 08:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I just got my injectors back from Witchhunter; they slightly improved the flow and the injectors are better balanced (their data sheet).
I painted the injector bodies and let them dry. I had them on a sheet of paper which blew off of the table and dumped all the injectors on to the floor. I could not see any damage. I installed them and fired up the car, but it ran like crap (it was running well before the injectors were cleaned). So, I started to poke around checking for spark from all 4 wires and it was present. But now I could smell gas and found a puddle beneath my car dripping from the heas exchanger/muffler flange connection on the drivers side. I pulled the injector 3 & 4, placed them in glass jars and turned the ignition on; they squirted once and did not leak. I then started then engine and it immeditely reved up and the injectors were spraying; it appeared they were pulsing, but with the revving engine it was hard to tell if they were pulsing or on solid. Cylinders 1 & 2 seem to be running normally. I am not sure why these cylinders are flood. Does any one have any ideas? |
tradisrad Cylinders 3 & 4 flooding Nov 14 2011, 08:42 AM
underthetire Pull 1 and 2 and see if they match the output of 3... Nov 14 2011, 09:37 AM
tradisrad
Pull 1 and 2 and see if they match the output of ... Nov 14 2011, 09:49 AM
Tom_T
Could hitting the floor damage the injectors?
... Nov 14 2011, 12:58 PM
tradisrad I did not try them before painting as they came ba... Nov 14 2011, 02:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 01:07 PM |
