DrifterJay needs help!!!, Anyone have this laying around? |
skline |
Aug 7 2004, 09:10 PM
DrifterJay (Jared) brought his engine over today for me to take a look at and see if I could fix it. We thought since he over-revved the engine he may have bent a valve. Not so, pulled the valve covers and everything is working perfect. So we pulled the heads and I found the problem. He got a broken oil ring on the #3 cylinder and it ruined his new cylinder. So he now needs to locate a single 96mm piston, cylinder and rings for a 71mm crank. Anyone out there have one laying around??
He is begging and saying "Please, Please, Please!!!" Attached thumbnail(s) |
Red-Beard |
Aug 7 2004, 10:24 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Actually, I have 2 extra 96mm pistons and cylinders. I don't have the rings, but thhose should be easier to get.
James |
bongo monkey |
Aug 7 2004, 10:40 PM
Dented member Group: Members Posts: 164 Joined: 10-August 03 From: Hamilton, NJ Member No.: 1,011 |
I had a similar problem a few months ago. I emailed the guys at aircooled.net and they hooked me up with a single 96mm piston and cylinder.
When I emailed them, they only had 96mm sets, but now they've started carrying singles, so you can get it from them if you can't find anyone with a spare. Piston and Cylinder Not sure if it's for a 71mm crank... you might want to email the guys there about that. Also, Just a single cast piston with a 71mm stroke. |
DrifterJay |
Aug 8 2004, 12:04 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
bump.. (IMG:style_emoticons/default/wink.gif)
skline |
Aug 8 2004, 11:01 PM
Jared, I sent an email to James but have not got a reply yet. Did you send him one also??
Lo-Fi Version | Time is now: 10th May 2024 - 11:53 PM |
