> Rebuilding shift console: quick questions
stugray
post Nov 14 2011, 08:26 PM
I have taken apart my stock shift console and found one item that could be causing a huge headache for these shifters.
There is a small pin that allows the shifter ball joint to pivot.
You can see it in the picture here on the left:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1321323965.1.jpg)
So this pin is worn out and out of round as well as being very loose in its "socket".
It would be a little difficult to replace for the average DIY-er as the bracket that holds it in is brazed in place.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1321323965.2.jpg)
Has anyone replaced this pin?
I am guessing a welded "bung" and a threaded pin with backup nut would solve the problem.
Also in the pic, see the "dimple" in the hole for the shifter on the right?
Is that supposed to be there, or did this one get dropped?
Stu
dlee6204
post Nov 14 2011, 08:30 PM
Howdy
I can't help with the pin but that dimple is suppose to be there.
McMark
post Nov 14 2011, 09:04 PM
914 Freak!
That plate is only on the earlier shifters. Later shifters ditched it. Also, that plate is supposed to be spot welded into place. That one had broken off and someone repaired it.
Get a new shifter. (IMG:style_emoticons/default/thumb3d.gif)
Eric_Shea
post Nov 14 2011, 09:53 PM
PMB Performance
Get a new shifter
Hmmm would you happen to know where one is? (IMG:style_emoticons/default/biggrin.gif)
Joking because I sent one off to Mark for his swap meet.
McMark
post Nov 14 2011, 11:01 PM
914 Freak!
Oh yeah! Buy Erics nice shifter. I'll
Pm pics tomorrow.
ConeDodger
post Nov 14 2011, 11:16 PM
Apex killer!
Pretty sure I have a late one on the shelf I can bring down Mark...
- Lo-Fi Version Time is now: 12th November 2026 - 02:23 PM
