Rebuilt motor, cam identification |
Cool914 |
Nov 14 2011, 09:12 PM
Member Group: Members Posts: 98 Joined: 25-January 11 From: Ontario Member No.: 12,627 Region Association: Canada |
I picked up a freshly rebuilt 2.0 engine awhile back but don't have much history on it. It seems it was set up for carbs and I will be using Djet and worried it could be a cam that will not be friendly to Djet. Is there any easy way to tell what cam I have, is there a marking on the end of them that I could see if i pulled the oil pump?
I dont want to intall it and set up the djet to test it out, I have a running 1.7 in for the meantime, rather break down the rebuilt to have a looksy over the winter, was going to do that anyway to make sure it looks all good (heads/pistion), but rather not split it if I don't have to. If i have to do that I will probably change it to a 2056 while I am there, and from what I have read a 9550 would be the way to go if so. If anyone has a an extra mount for the 2.0 air box (the one that goes on the intakes) let me know, it's the one missing peice I need for the 20 setup. thanks |
Lo-Fi Version | Time is now: 19th May 2024 - 11:21 AM |
