Should I buy this 914-6 conversion? |
Joseph Mills |
Aug 9 2004, 04:40 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
If I buy it, I'll probably have to sleep in it. (IMG:style_emoticons/default/biggrin.gif)
Part Pricer |
Aug 9 2004, 04:41 PM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Wow! Is that a factory color? (IMG:style_emoticons/default/w00t.gif)
Joseph Mills |
Aug 9 2004, 04:44 PM
Ooops!
Here's a pic: Attached image(s) |
seanery |
Aug 9 2004, 04:47 PM
what are the details of the car?
Ferg |
Aug 9 2004, 04:48 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Details? (IMG:style_emoticons/default/confused24.gif)
Doh! to slow... |
ArtechnikA |
Aug 9 2004, 04:56 PM
well - let's see... Italian turn signals, fairly rare & unusual. cowl-mounted battery disconnect (kill) switch, don't see that on many street cars - and none with batteries in the conventional location AFAIK - so the battery has almost certainly been relocated to the front. big NACA duct where the oil tank ought to be, so probably that's in the front too, to match the big oil cooler.
past that, i'm guessing just like you. looks 'close' to Olympic blue, just at first glance ... |
Joseph Mills |
Aug 9 2004, 05:01 PM
Wow Rich, that's pretty good! Here's some details.
2.2l six out of a 71 911T, 40IDA webers with MSD. Sideshift trans with 911 pull style clutch. Quick-six mounting bar and solid trans mounts. Front fiberglass fenders and bumper-1 piece removable with dzus fasteners Front brake are steel "A" calipers 76 911 turbo Rear brakes are "M" calipers 84 Carrera,vented rotors Adj. brake bias valve in the cockpit. Front struts are green bilstein 935 coil-over struts with raised spindles Front torsion bars 22mm and plastic bushings in the a-arms Rear shocks are yellow konis with 2 1/2" adj. coil-overs-200lbs springs Chassis stiffening kit with additional stiffening in the rear trunk Boxed trailing arms with plastic bushings Peterson dry sump oil tank mounted in front trunk ~5 gallons Oberg remote oil filter in the front trunk |
Joe Bob |
Aug 9 2004, 05:23 PM
Depends on the price....worth no more than 10K.....
Aug 9 2004, 06:45 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
QUOTE(joseph222 @ Aug 9 2004, 03:01 PM) Quick-six mounting bar ... Gack! (IMG:style_emoticons/default/barf.gif) QUOTE Front struts are green bilstein 935 coil-over struts with raised spindles Front torsion bars 22mm and plastic bushings in the a-arms That's not a good sign. Are they 935 coil-overs, with springs, or do they have torsion bars? If the latter, why would anyone put $$$$ parts designed for coil springs and keep the torsion bars? --DD |
Joseph Mills |
Aug 9 2004, 07:18 PM
QUOTE(mikez @ Aug 9 2004, 05:23 PM) Depends on the price....worth no more than 10K..... Mike, I think his asking price is 8,000.00 I just returned from driving my car and I'm way too attached to it to consider selling it. With the help of this board and some good friends, I have just completed an upper end engine rebuild with a rebuilt tranny (with 5th/3rd gear swap). I love my little four.(IMG:style_emoticons/default/wub.gif) So I guess this six is up for grabs. Might be a good deal for someone else on this board. I told him to post an ad in the classifieds. I'll be happy to give it a closer look for anyone interested. (IMG:style_emoticons/default/beer.gif) |
theol00 |
Aug 9 2004, 07:31 PM
Member Group: Benefactors Posts: 242 Joined: 22-January 04 From: Campbell, CA Member No.: 1,586 |
any rust in the car - if not - $8K looks like a fair deal
Lo-Fi Version | Time is now: 13th May 2024 - 09:01 AM |
