283, pic |
283, pic |
rey |
Aug 10 2004, 09:46 AM
Member Group: Members Posts: 97 Joined: 2-July 04 From: alviso,ca Member No.: 2,285 |
okay I have found that the 283 Is a block that I have is the one that can accept the 327 crank.,I not sure if that means anything. I believe that I have a stock crank. It has been bored over, cylinders are at 4 inches. So I have the cam,crank,rods ,and pistons back in and torked. This is an accomplishment for me cuz this is my first time at it.
Attached thumbnail(s) |
914werke |
Aug 10 2004, 10:02 AM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
UH ...your topic is kinda OT & NPC (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif)
Eric_Shea |
Aug 10 2004, 10:18 AM
QUOTE UH ...your topic is kinda OT & NPC With as many 914-8's as there are on this list I tend to doubt it... (IMG:style_emoticons/default/wink.gif) This is probably one of the best places to get -8 conversion info (IMG:style_emoticons/default/confused24.gif) |
thomasotten |
Aug 10 2004, 10:33 AM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
QUOTE(rey @ Aug 10 2004, 07:46 AM) has been bored over, cylinders are at 4 inches. Let's talk mm and cc, not inches! Oh wait, you are trying to use one of "those engines". |
GWN7 |
Aug 10 2004, 11:12 AM
If I remember the 302's were a 283 crank with a 4" bore
rey |
Aug 10 2004, 11:42 AM
UH ...your topic is kinda OT & NPC I guess what I tried to say is with a 283 block bored over and a 327 crank what cubic inch dose it make . This is a question for the v8 crowd sorry if it is inappropriate. Is the combination more desirable to hotroders. Is the block rare? |
JWest |
Aug 10 2004, 11:48 AM
327 crank (3.25" stroke) with 4" bore makes a... 327!
Before Chevy made the DZ302, hot rodders used to bore out 283s to 4" bore and use Ross (or others) pistons. They would call it a 301. But it is the same thing as a 302 - 3" stroke by 4" bore. The block is not rare, and if I were building a small journal engine I would rather start with a early 327 block that was 4" bore from the factory. |
DougC |
Aug 10 2004, 12:44 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
Rev, If you have a 283 that's been bored to 4" than you have a 302 (assuming you still have the original crank installed). This is the perfect engine combo (IMHO) for the 914 if using the stock tranny in particular. It closely matches what Chevy did in '67 and '68 for the Z28, which was very successful in "TransAm" racing, appairently. The engine got even better in '69 with the DZ302 which is large journal crank and 4 bolt mains block, etc.. The charicteristics of a 302 is nice since we don't need gobs of torque and most of the power is in the upper RPM range. This is the engine I'll eventually be turning my newly aquired 283 into (not possible on all 283s, BTW) but it is freshly rebuilt so I'll install it as is for now. IF, it has been opened up to a 4" bore then bigger valves are possible and a head change may already have been done (283 valves are probably too small). You should check the numbers on the block and heads to know exactly what you have. Good luck and keep us informed on your progress..
Doug C |
rey |
Aug 10 2004, 12:52 PM
Thanks DougC,
the cranck # is GM 2-3849847. Block # GM 3849852 other # on block 852 G8 O L7S The heads are big valves 2.02/1.60 (IMG:style_emoticons/default/beerchug.gif) |
DougC |
Aug 10 2004, 01:21 PM
Hey Rev I got info on my block number over on the other forum but someone here will probably help out - I don't have the publication or I'd post it. But, sounds like you're a bit ahead of the game with that setup you have..
Doug C |
Mike T |
Aug 10 2004, 07:46 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
www.mortec.com says:
crank= 3849847....283.......forged..small journal....3.00" stroke Block= CASTING#.....SIZE...YEAR...MAIN CAP BOLTS....NOTES 3849852........283...57-66.......2 So you got a 283 crank and a 283 block. Mike T |
rey |
Aug 10 2004, 07:59 PM
(IMG:style_emoticons/default/beerchug.gif) Thanks Mike T. (IMG:style_emoticons/default/beerchug.gif)
914gem |
Aug 10 2004, 11:12 PM
Member Group: Members Posts: 91 Joined: 5-January 03 From: Greenwood Arkansas Member No.: 89 |
rev, look on the back of the block. there should be a letter and 3 numbers. The letter is for the month like A would be Jan, B Feb and so on. The next 2 numbers will be the day and the last number the year. Example B035 would mean the block was built on Feb 3, 1965. All chevy parts has this casting ID
neo914-6 |
Aug 11 2004, 12:07 AM
Rey,
I couldn't download your pic. Here's my new 358, it's full of high end components. See you this weekend. Felix Attached image(s) |
rey |
Aug 11 2004, 10:57 AM
looking forward to it (IMG:style_emoticons/default/beerchug.gif)
Felix |
Andyrew |
Aug 11 2004, 11:30 AM
Ohhhh looks interesting felix! Is that aluminum heads?
Give us some details! |
neo914-6 |
Aug 11 2004, 02:18 PM
Andrew,
QUOTE aluminum heads? Yep, Edelbrock...I'll have more details later. Hope my "bitchin tranny" holds up. You have seen this engine before! (IMG:style_emoticons/default/wink.gif) The ride in the car with this engine nearly made me s*** my pants. (IMG:style_emoticons/default/laugh.gif) Felix |
Lo-Fi Version | Time is now: 15th May 2024 - 08:35 AM |
