| kbrunk1 |
Nov 21 2011, 08:49 PM
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
(IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) Just getting started bringing back a 73 2.0 Should I rebuild the master brake cylinder and brakes even if they seem to work?
Also need advice on how to get tar out of gas lines and injectors? |
| McMark |
Nov 21 2011, 10:03 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Safety first. Get good brakes on there. Pretty much every revived 914 that I run across has sticky calipers, and often have leaky master cylinders. If you're putting it into regular service, I would install a new 19mm master cylinder (just because it's cheaper than the stock 17mm), new rubber lines, and get rebuilt calipers from PMB.
If there is crap in the fuel system, it also should be thoroughly cleaned. Otherwise you put the engine at risk of damage. Remove the tank and at least clean it out, replace all the fuel lines, and spray cleaner and air down the lines in the center tunnel. |
| EdwardBlume |
Nov 22 2011, 07:11 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
Safety first. Get good brakes on there. Pretty much every revived 914 that I run across has sticky calipers, and often have leaky master cylinders. If you're putting it into regular service, I would install a new 19mm master cylinder (just because it's cheaper than the stock 17mm), new rubber lines, and get rebuilt calipers from PMB. If there is crap in the fuel system, it also should be thoroughly cleaned. Otherwise you put the engine at risk of damage. Remove the tank and at least clean it out, replace all the fuel lines, and spray cleaner and air down the lines in the center tunnel. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Mark is right. Clean out and replace the entire fuel system and then get the brake system in order.... assuming suspension, transmission, and structure is OK. |
| 76-914 |
Nov 22 2011, 09:47 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Tar???????????
| kbrunk1 |
Nov 23 2011, 09:41 PM
Should the tank be acid washed and or recoated or painted?
Is the original tank that was full of gunk re-salvageable? |
| swl |
Nov 24 2011, 10:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
| McMark |
Nov 25 2011, 02:21 AM
Pull the tank, remove the sender, filler neck, and bottom fittings. Hand it off to a professional for cleaning (BUT NOT COATING) or take your safety into your own hands and use muriatic acid to clean out the inside. Once all the old rust and scale is cleaned off and the tank is washed out with water (yes water) until no particulate is coming out. Then dry the tank with a heat gun, and apply this epoxy sealant. Done and you'll never have to deal with it again.
| kbrunk1 |
Dec 1 2011, 10:34 PM
How do you test the spray pattern of the injectors?
I assume you just pull them and depress the gas? Thanks Ken |
| SLITS |
Dec 2 2011, 08:12 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
How do you test the spray pattern of the injectors? I assume you just pull them and depress the gas? Thanks Ken Disconnect the coil HT wire at the coil so there is no spark. Pull them, put each of them in a glass jar and turn the engine over. You are looking for a conical spray coming from the end of them. When you have stopped cranking the engine, there should be no fuel dripping out of the ends. |
| rick 918-S |
Dec 2 2011, 08:32 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,247 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I just cleaned out a tank. I wasn't sure it was going to work buy others here have done this so I thought I would give it a shot.
http://www.914world.com/bbs2/index.php?sho...ning++gas++tank The inside of my tank was thick with rust and varnish. It looks like a new tank now. I'm goint to bump the link I posted and add my info there. |
Lo-Fi Version | Time is now: 18th April 2026 - 07:32 PM |
