Piston/Cylinders, Are they built well? |
davidj |
Nov 29 2011, 10:49 PM
Newbie Group: Members Posts: 41 Joined: 19-November 08 From: Ventura, Ca Member No.: 9,771 Region Association: Southern California |
I was lurking around today for some piston/Cylinder kits and came across these and wanted to know if they were good for a "Street Performance" engine. I do know that these are less expensive then the Nickeys. But still could be a good product.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.europeanmotorworks.com-9771-1322628561.1.jpg) 103mm Aluminum Alloy, NiCaSil-coated cylinder From European Motorworks $735.00 And then came across these from AA. And was wondering if these are better then the stock cast iron type? (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-9771-1322628561.2.jpg) 96MM ALUMINUM BIRAL CAST IRON PISTON/CYLINDER KIT $385.95 If anyone has any experience with these I would apreciate it to hear from you. Thanx, Dave |
mrbubblehead |
Nov 29 2011, 10:59 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i saw those too. and was wondering the same thing.
Chris Hamilton |
Dec 1 2011, 12:48 AM
Senior Member Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
So far I've talked to a few VW high performance shops and people online and the verdict is, they work fine but their quality control is terrible. So inspect them very carefully when you get them.
I have a set of them in 103s on the bench. When the motor goes into the racecar in the spring I'll let you know how it goes. quick edit: the ones I have are from QSC |
0396 |
Dec 1 2011, 02:00 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Sub
Mark Henry |
Dec 1 2011, 08:20 AM
IIRC Supertec sells them for the 911 crowd, he gets whole pallets and rejects something like 75-80% and sends those back.
The ones they send back are most likely the ones being sold on evilbay. |
davidj |
Dec 1 2011, 10:02 AM
So far I've talked to a few VW high performance shops and people online and the verdict is, they work fine but their quality control is terrible. So inspect them very carefully when you get them. I have a set of them in 103s on the bench. When the motor goes into the racecar in the spring I'll let you know how it goes. quick edit: the ones I have are from QSC Thanks for the info. Its good to know that you can get Niks for a good price. Please update when you have some hours on your set-up. (IMG:style_emoticons/default/beerchug.gif) |
Cap'n Krusty |
Dec 1 2011, 11:55 AM
I was lurking around today for some piston/Cylinder kits and came across these and wanted to know if they were good for a "Street Performance" engine. I do know that these are less expensive then the Nickeys. But still could be a good product. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.europeanmotorworks.com-9771-1322628561.1.jpg) 103mm Aluminum Alloy, NiCaSil-coated cylinder From European Motorworks $735.00 And then came across these from AA. And was wondering if these are better then the stock cast iron type? (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-9771-1322628561.2.jpg) 96MM ALUMINUM BIRAL CAST IRON PISTON/CYLINDER KIT $385.95 If anyone has any experience with these I would apreciate it to hear from you. Thanx, Dave "Birals" have iron liners and alloy fins. They are NOT to be confused with either "Alusil" or "Nikasil" piston/cylinder sets. It's old technology, used by Porsche (and, I'm sure, others) in the 50s and 60s. The Cap'n |
davidj |
Dec 1 2011, 01:21 PM
"Birals" have iron liners and alloy fins. They are NOT to be confused with either "Alusil" or "Nikasil" piston/cylinder sets. It's old technology, used by Porsche (and, I'm sure, others) in the 50s and 60s. The Cap'n (IMG:style_emoticons/default/agree.gif) What I'd like to know, are these (Birals) a better choice then the all iron type? (IMG:style_emoticons/default/beerchug.gif) |
Dec 1 2011, 01:33 PM
"Birals" have iron liners and alloy fins. They are NOT to be confused with either "Alusil" or "Nikasil" piston/cylinder sets. It's old technology, used by Porsche (and, I'm sure, others) in the 50s and 60s. The Cap'n (IMG:style_emoticons/default/agree.gif) What I'd like to know, are these (Birals) a better choice then the all iron type? (IMG:style_emoticons/default/beerchug.gif) Aluminum does a much better job of shedding heat than pure cast iron does...so they do that much better.. the core cylinder is still the same..its iron with no fancy coating to have issues with. Its also 356 technology..which has been replaced my the nickasil or alusil units a long time ago.... Rich |
Cap'n Krusty |
Dec 1 2011, 02:48 PM
"Birals" have iron liners and alloy fins. They are NOT to be confused with either "Alusil" or "Nikasil" piston/cylinder sets. It's old technology, used by Porsche (and, I'm sure, others) in the 50s and 60s. The Cap'n (IMG:style_emoticons/default/agree.gif) What I'd like to know, are these (Birals) a better choice then the all iron type? (IMG:style_emoticons/default/beerchug.gif) Aluminum does a much better job of shedding heat than pure cast iron does...so they do that much better.. the core cylinder is still the same..its iron with no fancy coating to have issues with. Its also 356 technology..which has been replaced my the nickasil or alusil units a long time ago.... Rich I'm at home today and can't look it up, but I think they used Biral until the 2.2 engines, and maybe the 2.4s.. ol, yes, but it's still viable technology. BTW, I think it was also used in aircraft engines, but I could be wrong. The Cap'n |
McMark |
Dec 1 2011, 09:35 PM
Have you read this article? LN Engineering. The third section talks about Birals. Good info.
Chris Hamilton |
Dec 2 2011, 12:18 AM
Don't mean to be negative, but you have to consider that the source you are linking to is an advertisement for a particular product. NPR made big-bore biral cylinders for type-IV engines for years and they worked great for a reasonable cost. |
sean_v8_914 |
Dec 2 2011, 08:56 AM
NPR is a HUGE company with vast experience. they make OEM for major Japanese car companies today
http://www.npr.co.jp/english/index.html only tetsing and real world experiences could convince me to use those new birals...or a sponsorship to test them |
davidj |
Dec 2 2011, 01:55 PM
Thanks for the info. Clearly a biased rant for thier product, but they do admit that: "biral-type aluminum finned iron-lined cylinders do typically cool better than cast iron cylinders" So I may try those if the Aluminum cylinders dont work out. (IMG:style_emoticons/default/beerchug.gif) |
maf914 |
Dec 2 2011, 02:01 PM
When LN Engineering first got started they offered biral piston/cylinder sets along with their Nickies. For some reason they chose to discontinue the Birals. I never read anything more about them.
maf914 |
Dec 2 2011, 02:47 PM
Thanks for the info. Its good to know that you can get Niks for a good price. Please update when you have some hours on your set-up. (IMG:style_emoticons/default/beerchug.gif) I don't think the 103mm aluminum cylinders shown above for $795 are Nickies. The LN Engineering web site indicates a price of $2131 for their Nickies and $3199 with JE pistons and ARP head studs added. I wonder who makes the $795 103mm aluminum cylinders shown? |
davidj |
Dec 2 2011, 03:20 PM
Thanks for the info. Its good to know that you can get Niks for a good price. Please update when you have some hours on your set-up. (IMG:style_emoticons/default/beerchug.gif) I don't think the 103mm aluminum cylinders shown above for $795 are Nickies. The LN Engineering web site indicates a price of $2131 for their Nickies and $3199 with JE pistons and ARP head studs added. I wonder who makes the $795 103mm aluminum cylinders shown? Yeah. I was asuming that the Aluminum Cylinders were Nikasil coated hence "Nicks". It will take some investagating to find out more about these cylinders. (IMG:style_emoticons/default/beerchug.gif) |
Dr Evil |
Dec 3 2011, 11:20 AM
Birals look like they take way more work for not much gain or profit. Others were making birals, no one was making nickies. Smart marketing. If these competition ones become reliable then the market may dictate lower prices on LN. You pay for name brand and high quality, but 4x more seems a bit steep.
Jake Raby |
Dec 3 2011, 11:42 AM
Birals look like they take way more work for not much gain or profit. Others were making birals, no one was making nickies. Smart marketing. If these competition ones become reliable then the market may dictate lower prices on LN. You pay for name brand and high quality, but 4x more seems a bit steep. Quality of Chinese knockoffs will never impact the price of Nickies by LN Engineering.. Because much like my company LN has diversified and does not depend on AirCooled cylinder/ component sales to continue to grow. As it stands now LN is happy selling most all their TIV cylinders to us... If I didn't buy any more, Charles wouldn't even care. The same extrusion is used for big bore Porsche M96 engines and now in our Subaru engines. The Nikisil plating process for LN cylinders alone cost more than the knockoffs sell for complete. Anyone waiting for the cost of Chinese knockoffs to reduce the cost of things like our engines and quality USA made components are waiting for Hell to freeze over.. The knockoff parts are only increasing the demand and cost of quality components and engines as one by one people learn that they can spend the money now or spend more later- either way it's gonna be spent. While others are cutting prices and competing we are busy having more parts made in USA and offering complete engines comprised of them. "Nickies" is a registered trademark of LN Engineering. |
gil914 |
Jan 21 2012, 09:20 PM
Newbie Group: Members Posts: 33 Joined: 2-January 11 From: Somerset, NJ Member No.: 12,558 Region Association: None |
. Anyone waiting for the cost of Chinese knockoffs to reduce the cost of things like our engines and quality USA made components are waiting for Hell to freeze over.. The knockoff parts are only increasing the demand and cost of quality components and engines as one by one people learn that they can spend the money now or spend more later- either way it's gonna be spent. Can you explain how lower cost component availability increases demand for higher cost components? Also I don't understand how the availability of lower costs components guarantees that in the event of failure that a higher priced alternative will be purchased. Could the consumer simply elect not to purchase the component, or purchase a different type of component (stock cylinder vs Aluminum, Subaru vs air cooled, etc.). Alternately, couldn't the consumer decide that the performance of a lower cost component, while not as good as that of a higher cost alternative, is nevertheless sufficient to justifty the cost differential? |
Lo-Fi Version | Time is now: 7th May 2024 - 03:24 PM |
