Any ideas? |
Any ideas? |
Bullet |
Aug 13 2004, 11:24 PM
Member Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 |
I cant for the life of me get my car to run well. I just had the MPS re-calibrated, got new spark plugs, Plug wires, cap & rotor, fuel injectors, CHT sensor, set the adjustment for the TPS, set timming. and it still has a miss-fire. I only have about 10 miles on a new rebuild. as i accelerate it will start to buck (surge). I cant get it to idle steady below 1500 rpm. my fuel pressure is at 28psi. my engine vaccum wobles between 12-15 in-lb's at idle. I have looked and looked for a vaccum leak, yet I cant find one. What am i missing?
Dr Evil |
Aug 13 2004, 11:31 PM
Have you checked the fuel points? I have a great set if you need one.
bondo |
Aug 13 2004, 11:51 PM
have you adjusted the valves?
ArtechnikA |
Aug 14 2004, 08:47 AM
i have an idea!
let's put useful and meaningful titles on our posts ! ( curmudgeon mode ...) |
Bullet |
Aug 14 2004, 09:55 AM
I have checked my fuel points and they are good. I adjusted the valves before i installed the motor in the car. I will go and double check that they are still where they need to be.
Dr Evil |
Aug 14 2004, 10:48 AM
Remember, for the valves there are two places that they can be adjusted to in the cycle. You want to adjust them for TDC on the ignition stroke, not the exhaust IIRC so right after the intake valve closes and your engine hits TDC that is the spot. I have had a problem with that on the bench before (learning curve).
Bullet |
Aug 14 2004, 06:45 PM
I was able to get the car to run almost perfect today. I checked the vale adjustment, and they where all dead nutz. Screwed around with it for a while with my co-workers and one of them sugest that I advance the timming a little more then the 27btc mark. I turned it just a little more advanced and it got better so i went a tit bit more advanced and it is damn near perfect. I was going to play with it a little more tomorrow. right at 5k RPM it starts to hicup a little. I think that it may just be possiable that with the cam that i got, I should have it a little more advanced then stock.
Lo-Fi Version | Time is now: 16th May 2024 - 05:52 AM |
