Jack stand blocks, I don't want to hijack Q's thread |
URY914 |
Aug 14 2004, 08:52 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,426 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I didn't want to hijack the thread that this came from so I thought I'd start another one.
QUOTE Hi, I like the blocks under the jack stands. How do you get the car high enough to get it on the stands that high? Will a floor jack get it that high? Cheers, Elliot My floor jack extends to 22" and I also add a 4" x 4" under the engine cross bar. I jack it up ass first, than the front. Not side-to-side as I think it is a little more stable front to rear. Here is a better picture of the jack stand blocks. They are made from two 2" x 12" with 2" x 4"'s standing on thier side between the 2" x 12". I added the handles because, well, why do you think I added the handles? Attached image(s) |
seanery |
Aug 14 2004, 09:34 PM
is the middle solid or hollow?
JeffBowlsby |
Aug 14 2004, 09:45 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
QUOTE My floor jack extends to 22" We are really disappointed Paul....we thought it was so light you just picked it up bare handed.... (IMG:style_emoticons/default/laugh.gif) |
Aaron Cox |
Aug 14 2004, 09:52 PM
wow. thats cool. (IMG:style_emoticons/default/wink.gif)
URY914 |
Aug 14 2004, 11:01 PM
"is the middle solid or hollow?"
The center is hollow. I could have used 2" x 6"s. "We are really disappointed Paul....we thought it was so light you just picked it up bare handed...." I have to be careful when using the jack. If I pump the handle to fast, the car flys up and hits the ceiling of the garage. (IMG:style_emoticons/default/cool_shades.gif) "wow. thats cool." Very low tech. Made from scrap wood after a project. Paul |
Elliot_Cannon |
Aug 15 2004, 12:02 AM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Thanks for the reply Paul. Nice idea. How about drilling some holes in the wood to make them lighter? LOL
Cheers, Elliot |
URY914 |
Aug 15 2004, 06:15 AM
Joe Ricard |
Aug 15 2004, 06:35 AM
I really like the rolling boxes that I have seen here before. Them boxes you made are plenty strong even for out heavy 1950 lb cars.
machina |
Aug 15 2004, 06:52 AM
QUOTE(URY914 @ Aug 14 2004, 10:52 PM) I didn't want to hijack the thread that this came from so I thought I'd start another one. I'll hijack it then, Picked up one of these jacks at PEP boys on sale. The proud owner in the picture has the motor/tranny up on the jack but the rear support (red arrow) is always in that elevated position. So what is the procedure? Jack up the motor only and then attach the tranny? If you do that then isn't it just an elevated platform? Any thought? dr Attached image(s) |
Curvie Roadlover |
Aug 15 2004, 07:07 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
QUOTE(URY914 @ Aug 15 2004, 07:15 AM) You should fill the insides with helium and then you could use the handles to attach strings connected to some bolts anchored into the floor to keep them from floating away. Attached image(s) |
URY914 |
Aug 15 2004, 07:10 AM
Couldn't you rotate the motor/tranny 90 degrees and than lower it while supporting the tranny?
Paul |
machina |
Aug 15 2004, 07:13 AM
QUOTE(URY914 @ Aug 15 2004, 09:10 AM) Couldn't you rotate the motor/tranny 90 degrees and than lower it while supporting the tranny? Paul that is a good idea, but I don't know for sure, never tried it. dr |
URY914 |
Aug 15 2004, 07:14 AM
QUOTE You should fill the insides with helium and then you could use the handles to attach strings connected to some bolts anchored into the floor to keep them from floating away. Now that is gooooooooood thinkin' I could use the helium that I have in the tires and in the roll bar. Thanks, Paul |
URY914 |
Aug 15 2004, 07:33 AM
I bought this tranny lift at Harbor Frieght a few months ago and haven't used it yet.
It cost $40 on sale. Will lift from 8" to 22" and lift 450 pounds. And the top pivots. Another fine quality product from China. Paul Attached image(s) |
URY914 |
Aug 15 2004, 07:39 AM
I can make some kind of a jig to fit the bottom of the engine and to fit around my tuna can. And use the floor jack under the tranny. It has a socket fitting for a racket handle and works like a screw jack.
Simple. (IMG:style_emoticons/default/biggrin.gif) Doubt if it will hold a -6. Those pigs weight over 450. Paul |
machina |
Aug 15 2004, 07:52 AM
QUOTE(URY914 @ Aug 15 2004, 09:33 AM) Paul I love this "quality" hardware from china. Especially the fresh smell of wet paint when you open the box. dr |
J P Stein |
Aug 15 2004, 08:55 AM
I call this pic "Pig on a lift".
Makes loading/removing the engine/trans unit a piece of cake. This particular pig makes 200+ hp. Eat your hearts out all you 4 pooper owners (IMG:style_emoticons/default/laugh.gif) My son and I lifed this long block onto an engine stand. I must be stronger than I thought (IMG:style_emoticons/default/rolleyes.gif) Attached image(s) |
J P Stein |
Aug 15 2004, 09:05 AM
Boxes with casters.....we gots those.
I hate jackstands......and I have to get 34 inches under the rear trunk bulkhead to remove/load the lump. Stable is gud. Attached image(s) |
nebreitling |
Aug 15 2004, 10:26 AM
i love those boxes, jp -- but how do you get the car up there? (and down!)
J P Stein |
Aug 15 2004, 11:53 AM
I have a cheepo floor jack with 18" of lift.
I jack the car up as far as I can, then block it. Drop the jack down and put blocks on the jack plate. Up we go again. Usually takes me bout 30 minutes doing it alone. I *can* roll the car around by myself once on the boxes.....but it's much easier/safer with another guy's help. A nice car lift would be gud, but that's money better(?) spent on the car. (IMG:style_emoticons/default/biggrin.gif) The RV lift requires a similar routine. It is stable as all get out. I have (literally) dropped a motor once or twice.....but not since I got the RV lift. |
Lo-Fi Version | Time is now: 7th May 2024 - 03:49 AM |
