euro heads/pistons on us car |
Gearren |
Aug 15 2004, 03:05 PM
Member Group: Members Posts: 91 Joined: 18-July 04 From: New Bern, NC Member No.: 2,362 |
I was looking on preformance products for new pistons and heads and I saw that they had the euro pistons/heads which are rated at more horse power, so will the euro pistons/heads fit on my 73 2.0 us 914, and if so do I have to make any adjustments or upgrades to accomidate the euro pistons.
seanery |
Aug 15 2004, 03:15 PM
not heads right? Cylinders?
You should be fine. They have a small bump in compression. Are you carbed or injected? |
ThinAir |
Aug 15 2004, 03:19 PM
Best friends Group: Members Posts: 2,541 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
The switch to "Euro" pistons and cylinders is a common upgrade. I'm doing it the the 73 2.0L engine that I'm overhauling right now. This style piston has a "flat" top rather than the "dished" top of the stock piston. The result is a slightly higher compression ratio, but not enough that you need to change anything else on the engine.
I've never heard of "Euro" style heads. |
Gearren |
Aug 15 2004, 03:29 PM
I'am carbed, and yea they are just pistons not heads.
seanery |
Aug 15 2004, 03:41 PM
being carbed, you can get a nice cam, like a web 494 (that's what I have) and get some nice torque for street driving. Or you could get more of hp cam, but on the street the 494 is more usable IMHO.
That is a nice combo (Euro P/C + webcam 494 + Weber 40s) |
thomasotten |
Aug 15 2004, 03:46 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Just as a point of caution, I have found Performance Products to be the bigest rip off there is, when you compare pricing. Check this out: I was looking at 914/6 heat exchangers, they want $2,082.95/pair. Tweeks has the same thing for $1,599.99. What a rip! (IMG:style_emoticons/default/alfred.gif)
What are they asking for these pistons? |
Gearren |
Aug 15 2004, 04:13 PM
where is the best place to get a webcam 494.
Brad Roberts |
Aug 15 2004, 05:38 PM
Buy direct from WebCam.
B |
Gearren |
Aug 15 2004, 05:42 PM
What are are good brand of euro pistons to get and where.
seanery |
Aug 15 2004, 06:11 PM
Performance isn't a rip off. First of all, they will give you PCA discount if your a member (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/wink.gif) . Also, they usually have the stuff in stock. When I lived in LA, we'd go up there a couple times a month.
There will probably be lower prices elsewhere, however. |
newdeal2 |
Aug 15 2004, 06:46 PM
Unregistered |
QUOTE(Gearren @ Aug 15 2004, 02:13 PM) where is the best place to get a webcam 494. I can get you a webcam. Contact me at pwingfield1@tampabay.rr.com Peter |
newdeal2 |
Aug 15 2004, 06:51 PM
Unregistered |
BTW...you will also need new lifters that match the Webcam. Figure retail at $158.00 for the cam and $140.00 for the lifters.
seanery |
Aug 15 2004, 07:22 PM
yup, need the lifters, too.
I found them online for $118. Cam was cheaper, too $147. Carlos gave me the link to this place. I looked everywhere and couldn't find a better price. Import Performance Parts - Webcam Lifters Import Performance Parts - WebCams |
ThinAir |
Aug 15 2004, 09:15 PM
Before you go buying lifters, you might want to search this site for topics about lifters. There has been a real problem in recent months with the quality of lifters and the only thing you can really trust is ceramics from LN Engineering or the new ones that Jake Raby is working on. I've experienced what happens when you have lifter problems. A flat cam is no fun!
anthony |
Aug 16 2004, 12:45 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Why go with Euro pistons when you can go for 96mm cylinders/pistons and end up with a 2056 engine?
rhodyguy |
Aug 16 2004, 08:46 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,073 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
for about the same $$ you can step up to forged 96mm pistons and cyl from aircooled.net.
kevin |
Lo-Fi Version | Time is now: 7th May 2024 - 06:10 AM |
