> clutch cable, Clutch cable
partwerks
post Dec 12 2011, 02:23 PM
First, does anyone know the size of the nut that goes on where you adjust the terry cable back by the clutch fork, as my mechanic lost/forgot to put the second nut back on and I plan on getting another one at Ace, but don't recall what size it is.
I put on that delrin pulley on back, but also was wondering if that bolt should also be replaced as maybe it has some wear with a bit of play in it as well??
I adjusted the cable and when the clutch grabs, the pedal is about 2" off the floor board. Is that about the correct distance. If not, do I need to tighten it or loosen it?
After waiting about 5 seconds to put in reverse, it does not grind into gear. Is that any indication?
- Lo-Fi Version Time is now: 22nd November 2026 - 08:48 AM
