| Gatornapper |
Dec 8 2019, 04:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,293 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States
Robert -
My first choice for sure - but currently out of my budget. Know of a better price than $450? Of course I'll take contributions...... GN Engine quit running on Nov. 10th after running like new on Nov. 3rd with new .060 idle jets and getting carbs dialed in...have spent hours searching for cause because ignition is all new. Today discovered bad dizzy stuck in 27 deg. advance - no wonder she wouldn't start. One spring missing...... Weighing my decision on new dizzy & Pertronix ignitor, dumping points.... GN Get the 123 Ignition. |
| DRPHIL914 |
Dec 8 2019, 08:14 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Today I did a few small things, I rotated the tires rear to front and the front to rear. Looking at tire wear it’s obvious the fronts had more wear inside than outside, rears were same, so it looks like I have more camber I’m front and none in rear.- will discuss that more on my suspension thread, but also I removed the front spacers and I put in the new 914rubber front control arm bushings then took it for a test drive.
Then I mounted my CHT gauge I got from Dakota Digital, worked on the wiring , almost ready to hook it up. The I installed my heater blower I got a few months ago from kevin(Rhodguy), thanks Kevin! It works as advertised! Sorted thru some parts. I will be listing a few soon in classifieds, Then put in some new shiny parts i got from Bruce Stone, the cup washers and retainer bolts that hold the upper front struts in place wow what a difference! -our with some old and in with some new. - new fan in place- was 42 the other morning I was glad I had heater hose hooked up and seat heaters! Attached thumbnail(s) |
| AZBanks |
Dec 8 2019, 10:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region
| AZBanks |
Dec 8 2019, 10:59 PM
(IMG:style_emoticons/default/smile.gif) Arizona and sun sound like good ideas (IMG:style_emoticons/default/smile.gif) btw. I might have a set of re-chromed (from G-Car) foglight grills, if you are looking. I have been trying to figure out what to do with the fog light openings. Send me a pm with the details on the foglight grills. |
| euro911 |
Dec 9 2019, 02:11 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,944 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
I swept out my RV garage in AZ today ... then looked around for a bunch of parts to bring back to CA - some for 'HOWARD' (our '71 914), and some parts for other World members.
Looks like I need to find a solution to a rodent issue I came across too (IMG:style_emoticons/default/sad.gif) ... As I was sweeping up, I heard some gnawing sounds that appeared to be coming from a transaxle crate, so I wheeled it outside and will open it up tomorrow (Monday) to see what's going on in there. Hard to believe a rat could have squeezed through any of the very small crevices the crate's door or lid has (IMG:style_emoticons/default/confused24.gif) Need to suit up and put on a mask to get rid of this mess as well (IMG:style_emoticons/default/yikes.gif) Side note ... I should have hired a contractor to apply a nice floor coating before I moved all the parts from my shop into this garage (IMG:style_emoticons/default/dry.gif) ... I plan to move everything out of the 2-car garage into the RV garage and have that floor coated first ... then I'll have to figure out how/when to get the RV garage done. |
| dcecc1968 |
Dec 9 2019, 06:52 AM
Member ![]() ![]() Group: Members Posts: 256 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
Change the transmission oil and replaced my leaking speedo drive gear bushing with one of 914Rubber's new improved bushings. Three things I learned
One, oil leaking from that bushing can spray all over the place to the point that it appears your trunk is leaking oil Two, Had a bugger of a time figuring out how the threads/nuts worked and the order in which to loosen things to take off the bushing, until I got it out, then it all made sense. Three, and most importantly.... NO MORE LEAKS! |
| mmichalik |
Dec 9 2019, 04:33 PM
MikeM ![]() ![]() ![]() Group: Members Posts: 804 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California
My daughter is going to get the black on black '74 when she turns 16 in April and, her new plates arrived today. Her middle name is Moon.
| michael7810 |
Dec 9 2019, 05:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region
Drove it to a funeral in north Phoenix and was greeted with this on the drive home. Once again I’m glad I have heat and defrost
| euro911 |
Dec 9 2019, 08:38 PM
WOW (IMG:style_emoticons/default/huh.gif) ... we got a little bit of hail up in Payson, but nothing like that (IMG:style_emoticons/default/screwy.gif)
| KSCarrera |
Dec 10 2019, 05:46 AM
Member ![]() ![]() Group: Members Posts: 364 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
Started the bumper swap to lightweight Euro-style mouldings. Hard for we Europeans to believe all this cr@p lurks behind the US-spec rubber bumpers! (IMG:style_emoticons/default/biggrin.gif)
| Jett |
Dec 10 2019, 05:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,700 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest
Putting the last few bits of interior back in our 75 2.0... Targa pad, new lighter unit, and windshield pillar trim... fitting the stereo tonight and last few pieces of NOS carpet.
still looking for speaker to housing mounting brackets and flathead screws... |
| ndfrigi |
Dec 10 2019, 06:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,993 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Started the bumper swap to lightweight Euro-style mouldings. Hard for we Europeans to believe all this cr@p lurks behind the US-spec rubber bumpers! (IMG:style_emoticons/default/biggrin.gif) ![]() ![]() |
| KSCarrera |
Dec 11 2019, 02:47 AM
I couldn't believe the weights of the US bumpers when I read it on here - along with a warning to get help when removing the rear bumper... I did it by myself and just managed to duck out of the way when it crashed to the floor! :-D
| Tbrown4x4 |
Dec 11 2019, 03:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 709 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None
My wife says you can't trust bathroom scales.
| nein14 |
Dec 12 2019, 03:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 6-February 03 From: USA Member No.: 262 |
| nein14 |
Dec 12 2019, 03:39 PM
| soccerplyr |
Dec 12 2019, 08:20 PM
Newbie ![]() Group: Members Posts: 25 Joined: 31-August 13 From: Sandy, Utah Member No.: 16,329 Region Association: Rocky Mountains |
I put in a new throttle position sensor. Easier then I thought it would be. Don't know if Gary Cotton is on the world, but thanks for the detailed how to on youtube.
| sb914 |
Dec 15 2019, 07:26 AM
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,687 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California
| KSCarrera |
Dec 15 2019, 07:37 AM
| mmichalik |
Dec 16 2019, 12:45 AM
Put in my spokeworksled.com led brake lights and side markers on the 74. What a huge difference they make. Can't wait to get the reverse and turn signals put in. They are great!
Also put in the 914rubber.com led head lights. Amazing, they are literally night and day different. All bright and shiny here now! |
Lo-Fi Version | Time is now: 15th September 2026 - 01:11 PM |
