first start of new motor, do I prime the oil pump?, should I have to prime it manually... whats wrong? |
Jake Raby |
Dec 27 2011, 02:03 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Filling the oil filter means you are expecting AIR in the primary oil system to PUSH the oil out of the filter and through the engine. Allowing the system to fill and bleed naturally is the only thing that works. Loosening the filter as the Cap'n mentions is also very effective.
Air won't push oil very well at all.. |
brant |
Dec 27 2011, 02:10 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Filling the oil filter means you are expecting AIR in the primary oil system to PUSH the oil out of the filter and through the engine. Allowing the system to fill and bleed naturally is the only thing that works. Loosening the filter as the Cap'n mentions is also very effective. Air won't push oil very well at all.. I definitely screwed up on that one how bad would the 8-9 attempts to crank be? (given that everything was well pre- lubed at assembly) do you prefill oil filters on routine oil changes?..... or always put filters on dry for even routine oil changes? |
stugray |
Dec 27 2011, 02:22 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Brant,
I once fired up a newly rebuilt K Ghia engine for~45 seconds before I realized I still had the case of oil at my feet. It ran happily for many-many years after that with no problems. I would not sweat it. Also funny, I was going to post this very thread yesterday but got distracted. I am also about to fire up my new engine in the next month or so (with a Raby Cam as well). I even lost the type-IV engine build DVD and had to buy another one for myself for Xmas. Thanks Jake! Stu |
jmill |
Dec 27 2011, 02:28 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
The only filter I've ever pre-filled was on my old 1953 chevy. That was old school filtering. Open the top, drop 2 rolls of toilet paper in, fill it up and replace top. The new scented 4 ply fluffy stuff would never work. I used the 80 grit pure paper stuff you find at only the finest service stations.
stugray |
Dec 27 2011, 02:51 PM
So while on this topic: What is the consensus on what engine assembly lube to use?
I have heard: Oil only Oil plus cam grease on the cam only Engine assembly lube everywhere, but you must use the right type..... Which is it? (sorry, havent watched the whole type IV assembly video) Stu |
McMark |
Dec 27 2011, 03:35 PM
Stu, every engine builder will give you their gospel on that one. I like the "Oil plus cam grease on the cam only" setup.
Mark, as mentioned in other posts, you can decrease the oil pump-up time by removing the oil filter and using a oil squirter thingy (see below) with a bit of hose on the nozzle to get some oil directly into the pump via the outer hole in the oil filter console. You need those gaps between the pump gears to be sealed by oil before they'll really start to pump. Sometimes it can take while, especially if your battery or starter are slow. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.alltradetools.com-419-1325021713.1.jpg) Attached image(s) |
doug_b_928 |
Nov 5 2023, 10:09 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Somewhat reluctantly (because it's oil-related, but at least it's not brand/grade specific) resurrecting this thread after having watched the linked youtube video below by Lake Speed. I went through a period of adding some oil to my filters during oil changes in all of my cars until I read Jake's comment linked above. I realize that was in the context of a new engine, but figured if it wasn't necessary on a new engine it shouldn't be on one that has residual oil in all of the moving parts. Based on Lake's video I guess I should go back to pre-filling. What do you make of this? Here's Lake's video: https://www.youtube.com/watch?v=939WTeorBnQ
Geezer914 |
Nov 5 2023, 10:43 AM
Geezer914 Group: Members Posts: 1,421 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
So if the oil filter is installed empty isn't there more air in the system vs prefilling the oil filter? (IMG:style_emoticons/default/confused24.gif)
technicalninja |
Nov 5 2023, 01:33 PM
Senior Member Group: Members Posts: 1,237 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I haven't had to try this on a T4 but on the very worst designed oiling system in the history of internal combustion engines this works GREAT!
Engine in question is the early "odd fire" 231 ci V6 that GM use in a bunch of stuff from the late 70s though the mid 80s. You could change the oil and loose the "pump prime" on these. Lots of engines were destroyed by poorly done oil changes... Remove either the oil filter OR the oil pressure sender and apply oil under pressure into the engine. We would remove the sender and install a hose we made up to a facet fuel pump (square box style). The inlet side of the fuel pump would get a hose that we'd put into a quart of oil. We would apply 4psi oil to the engine and then turn it backwards for 360 degrees which would prime the pump. This was the only way that worked every single time. Sort of a PIA but when nothing else would work this method did. After the "set up" was created the time it required to do this was under 5 minutes. I ALWAYS pre-pressurize a fresh motor in this manner after a build. Normally it's still on the engine stand out of the car. After install I kill fuel/spark and rotate it with the starter motor until the gauge sees pressure. If I can I fill oil filters before install during a normal oil change. Some designed do not allow this. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:57 PM |
