> Just need confirmation, oil pressure sending unit VDO
jsayre914
post Dec 30 2011, 12:06 PM
Speed Up !!!
I purchased an oil pressure guage. The 80psi style with its matching sender. When I recieved it it says 80psi on the guage just like the picture in the catalogue. But, the sender has a sticker that says 360-023 m10x1, 150psi
I do know there are diff guages and diff senders, but I was told by Zach it will not work, and the vendor says it will be fine? that sender works all the guages
Anybody
orange914
post Dec 30 2011, 12:24 PM
http://5starmediaworks.com/index.html
Does the sticker look factory original? If it is correct, the ohm values correlating to gauge will range differently. I'm just dealing with this on my 83 VW diesel. Installing lower pressure gas o.p. console gauge package in high o.p. diesel.
VW'S.... hmmmmmmmph...
underthetire
post Dec 30 2011, 12:32 PM
Think zack is right.
TC 914-8
post Dec 30 2011, 12:46 PM
do a internet search and see what options come up. I remember wanting to replace my sending unit and several types were available. I have the same gauge and just looked at the sending unit, I couldn't see any #'s. (IMG:style_emoticons/default/confused24.gif)
sean_v8_914
post Dec 30 2011, 01:34 PM
Chingon 601
parts sellers are good at selling parts. due diligence is on you.
TC 914-8
post Dec 30 2011, 07:34 PM
I just got a good look at my sending unit, it has 0-80 psi stamped on the hex head. check what is stamped on yours, it should have the rating, 150 would be the wrong one (IMG:style_emoticons/default/sad.gif)
- Lo-Fi Version Time is now: 30th July 2025 - 10:55 PM
