| DRPHIL914 |
Dec 30 2011, 11:01 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,949 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I pulled the tank to get at fresh air blower., put it all bak together, so I ran down to the station to fill up. Had about a gallon and a half in the tank. Went to take the gas cap off, and there was a lot of suction on there. I only drove about10 miles to the station. And it's noit hot out. This is a 75 2.0 with d-jet. The only thing I can think of is that when I put the tank back in the vapor line got pinched .. is it possible this caused the negative pressure that fast. ? And if so can I just leave it disconnect the expansion tank until the tank level is low enough to lift ip to move the vapor line. ?
Phil |
| Mike Bellis |
Dec 31 2011, 01:39 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I crushed a tank once (not in a 914). The vent/vapor line was plugged. It does not take long for it to happen.
| 76-914 |
Dec 31 2011, 10:28 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,900 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
pull the cover from below (4 bolts) and you might be able to access any pinched lines and correct.
| Bob L. |
Dec 31 2011, 07:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Don't mean to hijack, just seems relevant...
Mine was converted to a carb (yes, singular) by PO. He plugged the return fuel line. So, basically there is just the fuel line out. Is this going to be a problem? Is my tank going to crush?!?! |
| BMITCHELL |
Dec 31 2011, 07:48 PM
Member ![]() ![]() Group: Members Posts: 328 Joined: 28-February 05 From: Moorpark, CA Member No.: 3,681 |
It still should be vented. Vent line on expansion tank going to the filler neck.
| Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Don't mean to hijack, just seems relevant... Mine was converted to a carb (yes, singular) by PO. He plugged the return fuel line. So, basically there is just the fuel line out. Is this going to be a problem? Is my tank going to crush?!?! My car has carbs and a blocked off return line. I think what they're talking about here is the "vent" line. It's a small line coming off the fuel cap I believe. |
| Bob L. |
Dec 31 2011, 08:23 PM
Don't mean to hijack, just seems relevant... Mine was converted to a carb (yes, singular) by PO. He plugged the return fuel line. So, basically there is just the fuel line out. Is this going to be a problem? Is my tank going to crush?!?! My car has carbs and a blocked off return line. I think what they're talking about here is the "vent" line. It's a small line coming off the fuel cap I believe. Then I'm good. This site is like reading a medical text book... every time I read about someones problem, I start to worry I have it too. Thanks, now I can (IMG:style_emoticons/default/gint2.gif) P.S. Happy New Year! |
| Racing916 |
Dec 31 2011, 08:47 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
I race my 914 with a 6 cylinder and the return capped off. If it is vented it should not have pressure built up. Make sure your vent line in not plugged.
| rgalla9146 |
Jan 1 2012, 08:26 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,972 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I race my 914 with a 6 cylinder and the return capped off. If it is vented it should not have pressure built up. Make sure your vent line in not plugged. Many years ago I had a factory slant nose Turbo in my shop with an inop. fuel level gauge. You guessed it, blocked vent caused pump ( pumps ! ..Turbo ) to suck that tank down so that it looked like it had been used to wrap your leftover sandwich. |
| DRPHIL914 |
Jan 1 2012, 10:00 AM
I race my 914 with a 6 cylinder and the return capped off. If it is vented it should not have pressure built up. Make sure your vent line in not plugged. Many years ago I had a factory slant nose Turbo in my shop with an inop. fuel level gauge. You guessed it, blocked vent caused pump ( pumps ! ..Turbo ) to suck that tank down so that it looked like it had been used to wrap your leftover sandwich. Is it possible that my charcoal filter is clogged or blocked? The plastic line runs from the relief tank back to the charcoal filter. I need a diagram of what and how the hook ups go on the filter too. May be the charcoal filter needs to be replaced? Just another thought |
| Mike Bellis |
Jan 1 2012, 11:59 AM
Never seen a charcol filter clogged but anything is possible.
Check out Jeff Bowlsby's site... http://bowlsby.net/914/Classic/ |
Lo-Fi Version | Time is now: 19th June 2026 - 07:16 AM |
