| billh1963 |
Jan 1 2012, 05:00 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,443 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
The wiring on this car is a mess....very few electrical items are working and I'm beginning to see why.
While putting together my plan of attack to pull the transmission tomorrow (if it's not too cold), I noticed this wire (clearly a hot wire) just hanging in space. Since the starter works fine, any ideas on where this goes? I'm looking at the wring diagram but I don't have enough 914 experience to figure it out yet. (IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1325458827.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1325458828.2.jpg) |
| jflash914 |
Jan 1 2012, 05:21 PM
Member ![]() ![]() Group: Members Posts: 80 Joined: 24-February 05 From: binghamton,ny Member No.: 3,652 |
The wiring on this car is a mess....very few electrical items are working and I'm beginning to see why. While putting together my plan of attack to pull the transmission tomorrow (if it's not too cold), I noticed this wire (clearly a hot wire) just hanging in space. Since the starter works fine, any ideas on where this goes? I'm looking at the wring diagram but I don't have enough 914 experience to figure it out yet. It plugs on to the starter solenoid. |
| 914itis |
Jan 1 2012, 05:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I think it is for the reverse light switch on the tranni. |
| TheCabinetmaker |
Jan 1 2012, 06:16 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Starter. Reverse switch has two wries with bullet connectors.
| billh1963 |
Jan 1 2012, 06:21 PM
| Tom |
Jan 1 2012, 06:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
How about another pic of the wires that go to the starter. Almost looks like the size to go to the starter hot post for the alternator, although that is the wrong terminal lug for that purpose. Could be a previous owner modification.
Tom |
| billh1963 |
Jan 1 2012, 06:56 PM
| TheCabinetmaker |
Jan 1 2012, 07:06 PM
Starter wiring is correct. Possibly a po added wire. Is it hot?
| TheCabinetmaker |
Jan 1 2012, 07:09 PM
Can you tell where it goes?
| 904svo |
Jan 1 2012, 07:46 PM
904SVO ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Is that the RED wire from the starter +battery terminal to the B+ lead to the alternator?
| SirAndy |
Jan 1 2012, 07:54 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,523 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
| dlee6204 |
Jan 1 2012, 07:55 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
QUOTE What is that rod going across your transmission??? Exactly what I was thinking... aftermarket swaybar? |
| billh1963 |
Jan 1 2012, 08:02 PM
| SirAndy |
Jan 1 2012, 08:06 PM
QUOTE What is that rod going across your transmission??? Exactly what I was thinking... aftermarket swaybar? It is a sway bar. Can you post some pics of that setup? I'd like to see it ... (IMG:style_emoticons/default/idea.gif) |
| Tom |
Does this car have a solenoid operated trunk release?
Starter wiring looks correct and you do have the large alternator wire hooked up/ Has to be something added by a previous owner. Tom |
| billh1963 |
The battery is disconnected so I can't tell if it's hot. I'll check tomorrow.
When the car starts the alternator light comes on and stays on. However, When I put a DMM on the battery it appears to be charging (shows around 13.5V). Maybe it is alternator related. |
| yellowporky |
Jan 1 2012, 10:30 PM
Member ![]() ![]() Group: Members Posts: 446 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
could the wire be from a starter booster relay and the relay was removed? I had one on an old car i had that had problems with hot starts.
| shoguneagle |
Jan 1 2012, 11:05 PM
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I think 904SOV may have where the wire goes, but I think it is time to get a good volt/ohm meter and start tracing some of these suggestions to verify them to the wiring schematic. This is the start off learning the wiring requirements.
When you are in an area such as the engine, ask yourself what can a specific wire go to and where would it be used. The wire is a B+ wire and looks like it is the right size required in the Alternator. Anyway, it looks like it can take a fairly large load. Take your time and enjoy learning the wiring problems. Give yourself time and you will surprise even yourself; double checking is always a must when dealing with electric problems. Try to understand the sub-systems an how the are wired. |
| yellowporky |
Jan 1 2012, 11:58 PM
http://www.pelicanparts.com/914/914_electrical_diagrams.htm
If the car in general has electrical issues this link might help |
Lo-Fi Version | Time is now: 28th September 2026 - 02:26 AM |
