I finally got my revolution wheels, But what size tire should i get??? |
jporsche914 |
Aug 24 2004, 08:18 PM
Member Group: Members Posts: 149 Joined: 9-March 04 From: colorado, springs Member No.: 1,769 |
These wheel are bitchin. (IMG:style_emoticons/default/aktion035.gif) They look 10 times better when you actually see them a touch them. Now it is time to pick a tire size. I have been eyeing up the kuhmo ASX tires for a while and i think those are the tires i want. My question to you guys is what size should i get. I want to keep the speddometer as close to stock as possible so 205/40 are out of the question. The size that i really want is a 215/45/17. So i was wondering how much wider a 205/45/17 compared to a 205/50/17 and will the 215/45 fit without rubbing??
Thanks alot, James |
Aaron Cox |
Aug 24 2004, 08:29 PM
jporsche914 |
Aug 24 2004, 08:40 PM
I dont have anyway to post pictures sorry
F4i |
Aug 24 2004, 10:05 PM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
If you got your wheels then I should get mine soon. I hope...
I am going with 205 50 17. the speedo will be the same and they are about as wide as I dare. |
jporsche914 |
Aug 31 2004, 07:28 PM
So you dont think the 215/45/17 will fit? Do you know how much wider the 215 is over th 205?
Mueller |
Aug 31 2004, 07:36 PM
QUOTE Do you know how much wider the 215 is over th 205? 10mm or .394" (IMG:style_emoticons/default/smile.gif) seriously, use the power of the Web !!!!!! go to tire rack dot com, pick the brand you want, go the "specs" and you'll get your answer, or at least close to it........ how stock are your rear fenders? (rear fenders are problem, you can put wider rims/tires up front) the 205 tire is a perfect match for a 7" wide rim i have 205/45/17's on my revolutions |
jporsche914 |
Aug 31 2004, 07:42 PM
My fenders are stock. What tires do you have on your revolution wheels?
Mueller |
Aug 31 2004, 07:45 PM
Yokohama AVS ES100....got mine at Americas Tires
Elliot_Cannon |
Aug 31 2004, 10:52 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Hi,
I'll be mounting 205 50 17 on mine. That comes closest to the stock diameter. I think that size tire should fit under a stock fender. I may roll my rear fenders and try 215s. 225s would be even better. What is everyone using for spacers in the front? Cheers, Elliot |
Aug 31 2004, 11:00 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Mueller @ Aug 31 2004, 06:36 PM) 10mm whoohooo, Muller goes metric!!! i tell 'ya, metric is sooooooo much easier ... 215mm - 205mm = 10mm doh! (IMG:style_emoticons/default/biggrin.gif) Andy |
maf914 |
Sep 1 2004, 07:11 AM
QUOTE(SirAndy @ Aug 31 2004, 09:00 PM) i tell 'ya, metric is sooooooo much easier ... Tire sizes are given in metric, but with english units for the wheel size. What's up with that? (IMG:style_emoticons/default/wacko.gif) Mike, Can you get those 205/45's on 7 x 17 Revolutions under the stock rear fenders? What kind of backspace or offset do they have? |
Mueller |
Sep 1 2004, 10:24 AM
QUOTE Mike, Can you get those 205/45's on 7 x 17 Revolutions under the stock rear fenders? yep, they are designed for the stock fenders.....I wouldn't try a larger tire...and to be honest with you there is no real reason except for bragging rights for most people (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 06:40 AM |
