EdArango |
914 Enthusiast ![]() ![]() Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California ![]() |
I'm the original poster. The reason I asked if there is another vendor wasn't based on price........I can pay the $400 bucks!! MONEY ISN'T THE ISSUE.
I wanted to see any other options out there and what I actually get for $400 bucks....GEEZ!! Ed |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
I'm the original poster. The reason I asked if there is another vendor wasn't based on price........I can pay the $400 bucks!! MONEY ISN'T THE ISSUE. I wanted to see any other options out there and what I actually get for $400 bucks....GEEZ!! Ed Maybe folks thought price was the issue when you said " Is there someone else that produces this at a more reasonable price?? ". Just saying (IMG:style_emoticons/default/blink.gif) |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I'm the original poster. The reason I asked if there is another vendor wasn't based on price........I can pay the $400 bucks!! MONEY ISN'T THE ISSUE. Ed Ed - That's good to know....I'm here for you buddy.... I have a set that look a lot like the ones pictured above but they come in a really fancy box. I'll sell them for $2000. Any time I can help you out, just let me know. Your friend, mark |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
I'm the original poster. The reason I asked if there is another vendor wasn't based on price........I can pay the $400 bucks!! MONEY ISN'T THE ISSUE. I wanted to see any other options out there and what I actually get for $400 bucks....GEEZ!! Ed Maybe folks thought price was the issue when you said " Is there someone else that produces this at a more reasonable price?? ". Just saying (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/agree.gif) When you make these, keep track of your time, your materials,your electric bill, your consumables and all of your friends time. Figure the time out by whatever you make for a living and get back to us as to what is a reasonable price for this kit. (IMG:style_emoticons/default/beerchug.gif) |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
I just priced out the heim joints at Pegasus. Your looking at $150 on the cheap. That's carbon steel rod ends with weldable tube ends. If you go with oversize shank alloy rod ends with a nickel plated race lined with PTFE fabric your looking at $280. That's just for the joints. I'd have a hard time coming in under $400 just for materials doing it myself.
OTOH - I could cob some angle iron in there for little to nothing. (IMG:style_emoticons/default/teef.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
from my racecar:
Attached image(s) ![]() |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
I just priced out the heim joints at Pegasus. Your looking at $150 on the cheap. That's carbon steel rod ends with weldable tube ends. If you go with oversize shank alloy rod ends with a nickel plated race lined with PTFE fabric your looking at $280. That's just for the joints. I'd have a hard time coming in under $400 just for materials doing it myself. OTOH - I could cob some angle iron in there for little to nothing. (IMG:style_emoticons/default/teef.gif) You point is well taken, however IMO you don't need premium grade super high strength rod ends for this application. I used 7/16" heims rated at over 10,000 lbs from McMaster-Carr for $15 each. But again your premise is sound; you still need to create a design, chase-down the parts, fabicate the plates and rods, and so on. I also chose to have the rods yellow zinc plated, so add yet more time and cost. Andys |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
What is the advantage of removable strengthening rods as opposed to welded other than the fact that they are removable?
Elliot Cannon |
I just re-read the whole thread and I see that now. I would be worried about a slight bit of play unless like it was stated in one of the previous posts they where machined to fit very snug. Good info in this thread.
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Removable rods are absolutely required for a -4 with full tin or for a -6.
The left and right threaded rod ends make installation/removal simple. Non-threaded removable rods could be used but precise installation/welding would be critical. I use fairly inexpensive (non teflon) 3/8" rod ends in my kit but they're sufficiently strong and tight for the application, which is static (ie. no motion). Only 10% of the value of the complete kit is in the rod ends. 7/16" is overkill IMO, the bending loads are real small and 3/8" is fine in tension/compression. The mounting brackets for the heim braces, made in-house, are more costly than they may appear - they require specialized tooling and precise fabrication. I include long bolts to attach the rod ends because shorter bolts would have the threads inside the hole, allowing movement in the assembly. The tubes are 1" od x .065w Chrome-Moly (primed only), which is plenty stiff without adding much weight. We weld the threaded bushings in-house. All the sheetmetal is CNC plama-cut and formed, in-house. I think I've done about everything I can to control costs without cheating on the value of the final product. |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
I've bought 2 of the suspension ear reinforcement from Chris! He makes a great product & it is worth every penny. If you don't want the complete kit. Just by the ear reinforcement & do whatever you want for the brace to the firewall. After seeing many suspension ear cracks. I will be adding the reinforcement piece to every 914 I buy. Just good insurance against a break. I won't add the brace to the firewall on a Daily driver. If your autoxing then go full out (IMG:style_emoticons/default/biggrin.gif)
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Removable rods are absolutely required for a -4 with full tin or for a -6. This is not true on many levels....not the least of which is the fact that the engine installation with sheet metal in place is not required on a six. This makes moot the fact that my set up clears the tin. |
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
[quote name='JRust' date='Jan 6 2012, 09:16 PM' post='1600949']
I've bought 2 of the suspension ear reinforcement from Chris! He makes a great product & it is worth every penny. If you don't want the complete kit. Just by the ear reinforcement & do whatever you want for the brace to the firewall. After seeing many suspension ear cracks. I will be adding the reinforcement piece to every 914 I buy. Just good insurance against a break. I won't add the brace to the firewall on a Daily driver. If your autoxing then go full out (IMG:style_emoticons/default/biggrin.gif) Question for Chris.. I order a suspension ear reinforcement from Chris' site this morning. My question is , do the reinforcememts come 'prebent' to mold to the suspension ear as pictured on his web site? |
ChrisFoley |
Question for Chris.. I order a suspension ear reinforcement from Chris' site this morning. My question is , do the reinforcememts come 'prebent' to mold to the suspension ear as pictured on his web site? The Paypal link has a pulldown menu to select either flat or prebent.I believe you ordered the flat ones. |
0396 |
Question for Chris.. I order a suspension ear reinforcement from Chris' site this morning. My question is , do the reinforcememts come 'prebent' to mold to the suspension ear as pictured on his web site? The Paypal link has a pulldown menu to select either flat or prebent.I believe you ordered the flat ones. I did not see the pull down.. can you please sends prebent?.... I revisited your site and figured it out.. If you've sent it, I'll deal with it. Thanks |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
I bought the ear reinforcements too and they work great.... at least I think so... I'll let you know if they fail in the next 35 years or so... (IMG:style_emoticons/default/cheer.gif)
Lo-Fi Version | Time is now: 16th June 2024 - 05:08 PM |
