3.6L conversion - relay board substitute question |
mharmon |
Jan 4 2012, 12:05 PM
Member Group: Members Posts: 129 Joined: 1-November 06 From: Los Angeles Member No.: 7,133 |
In the middle of my 3.6L conversion and had a question. For those of you who removed the stock relay board, what relays did you end up keeping in the car and where did you mount them?
I thought Hella made a nice, neat relay board mounting assembly, but it looks like they only make it for the mini relays. I want my set-up to look neat and professional, so don't want to just slap something together. Any ideas? Thanks. Mike |
Jan 4 2012, 12:22 PM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
In the middle of my 3.6L conversion and had a question. For those of you who removed the stock relay board, what relays did you end up keeping in the car and where did you mount them? I used the PMS adapter harness which eliminates the stock relay board. The DME comes with it's own relays, so there was no need to add any additional relays. The wiring was pretty straight forward ... (IMG:style_emoticons/default/popcorn[1].gif) |
jim912928 |
Jan 4 2012, 04:58 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I did the same thing Andy did with my 3.2l. PMS adapter harness, relay already part of the DME, took out the 914-4 relay board entirely. Nothing else needed.
mharmon |
Jan 4 2012, 05:18 PM
Thanks for the responses guys. I get that the fuel pump relay gets covered by the DME, but I guess you don't use the heater fan or the rear window defroster?
Steve |
Jan 4 2012, 05:26 PM
914 Guru Group: Members Posts: 5,588 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Not too many cars with rear defrosters and you no longer need the heater fan with a six conversion. I dumped the relay board years ago and just made a harness by reading the 914 and 911 Haynes manuals. The dme sits behind the drivers seat and dme relay sits behind the passenger seat. I installed longer back pad screws to hold them in place.
shoguneagle |
Jan 4 2012, 05:28 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Heater fan relay has to wired in separately. I eliminated the circuit board and changed the wiring on the 14 Pin Connector. Additionally wired in the heater fan relay, front fans for the front oil cooler, etc.
3.2 Sixer conversion. Steve Hurt |
jim912928 |
Jan 4 2012, 05:53 PM
Ah....sorry, missed the heater fan relay. If you don't have heat no need. Being in the midwest here I have heat and did use the stock electric blower/booster for heat. I added a Porsche style relay and socket (got a used one that you'd find pressed into the fuse panel in the passenger compartment) and mounted it next to the diagnostic plug (same size/pattern) in the engine compartment. Looks stock.
Series9 |
Jan 5 2012, 09:34 AM
On all the /6 conversions I do, I remove the relay board, remove the 14-pin female connector on the car side, replace it with a 14-pin male connector with the pins in the proper locations for the engine I'm installing and simply plug the engine into the car.
kfish914 |
Jan 5 2012, 12:32 PM
Member Group: Members Posts: 161 Joined: 7-May 08 From: Osceola, Indiana Member No.: 9,026 Region Association: Upper MidWest |
where would a home wanna be get hold of that 14 pin plug?
Jan 5 2012, 12:33 PM
where would a home wanna be get hold of that 14 pin plug? Junk yard. There's a thread here somewhere listing all the other models of cars that use the same type of connectors. (IMG:style_emoticons/default/popcorn[1].gif) |
kfish914 |
Jan 5 2012, 12:56 PM
Thanks, I wish I didn't suck at searchs
I will give it a shot (IMG:style_emoticons/default/biggrin.gif) |
ClayPerrine |
Jan 5 2012, 01:44 PM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Van914 |
Jan 5 2012, 07:49 PM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
I have on I bought from Perry Keil. I sold the car before I used it. For Sale $25 plus shipping.
Thanks Van914 |
Lo-Fi Version | Time is now: 18th May 2024 - 11:13 AM |
