2.0 sshe's ID vs ID of regular steel he's |
jimkelly |
Jan 5 2012, 08:18 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
for the record
Tom_T |
Jan 5 2012, 07:23 PM
Thanx Jim!
The SS wall is quite a bit thinner as well - maybe 50-60% less. |
pete000 |
Jan 5 2012, 07:25 PM
How about compared to stock 1.8 HE's ? Must be a really big difference.
jimkelly |
Jan 6 2012, 07:38 AM
pic
maf914 |
Jan 6 2012, 10:23 AM
If my calcs are correct, Area of Ellipse = 2.143 x A x B, where A = short radius and B = long radius which results in:
Area = 634 mm2 for the SS HE Area = 546 mm2 for the stock HE The SS HE pipe area is about 16% larger than the stock HE area. Not bad. But then you loose some sealing area due to the thinner wall tubing. |
Mikey914 |
Jan 6 2012, 10:33 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just courious. I assume that the OD is the same, but can you check?
Lo-Fi Version | Time is now: 24th May 2024 - 07:57 PM |
