jimkelly
Jan 5 2012, 08:18 AM
for the record
Tom_T
Jan 5 2012, 07:23 PM
Thanx Jim!
The SS wall is quite a bit thinner as well - maybe 50-60% less.
pete000
Jan 5 2012, 07:25 PM
How about compared to stock 1.8 HE's ? Must be a really big difference.
jimkelly
Jan 6 2012, 07:38 AM
pic
maf914
Jan 6 2012, 10:23 AM
If my calcs are correct, Area of Ellipse = 2.143 x A x B, where A = short radius and B = long radius which results in:
Area = 634 mm2 for the SS HE
Area = 546 mm2 for the stock HE
The SS HE pipe area is about 16% larger than the stock HE area. Not bad. But then you loose some sealing area due to the thinner wall tubing.
Mikey914
Jan 6 2012, 10:33 AM
Just courious. I assume that the OD is the same, but can you check?
