Pink Rubber Thing |
Pink Rubber Thing |
ruddyboys |
Aug 25 2004, 10:01 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I was under the car yesterday and noticed some dried out pieces of pinkish rubber. It seems to be comming from under the coil spring were it sits on the strut. The strut is black and says Blistein. The strut and coil both seem fine, the rubber could have dried out from 8 years sitting outside, can I get a replacement?
d7n7master |
Aug 25 2004, 10:04 AM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Pink Rubber Thing???
Go to any pharmacy and ask for a c-o-n-d-o-m (IMG:style_emoticons/default/wacko.gif) |
datapace |
Aug 25 2004, 10:13 AM
Member Group: Members Posts: 133 Joined: 19-January 04 From: Atlanta, GA Member No.: 1,579 Region Association: South East States |
Probably the remnants of a bump stop. They are thick chunks of rubber that fit over the shock/strut shaft to prevent damage to the shock and chassis during extreme compression.
Sort of like a "last resort". They should be avaliable separately although I think they come with new inserts when you get them. -datapace |
Aug 25 2004, 11:40 AM
QUOTE(d7n7master @ Aug 25 2004, 09:04 AM) Pink Rubber Thing??? (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Cap'n Krusty |
Aug 25 2004, 11:47 AM
IME, the bump stops don't come with the new inserts, and you REALLY need them. Wait 'til you hear what they cost .................................................... The Cap'n
HarveyH |
Aug 25 2004, 11:51 AM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
the Cap'n said
QUOTE Wait 'til you hear what they cost .... Just did the bump stops about $50. each for a piece of molded rubber with a flat washer fixed to the end... Ah fine German craftsmanship. Harvey |
balljoint |
Aug 25 2004, 12:14 PM
I checked out the price on those things too. $65.00 and only at the dealer, I decided that they probably wouldn't fit on the new replacement rear shocks so I left them off.
Very brittle crumbly pink rubber. |
ruddyboys |
Aug 25 2004, 12:46 PM
Of course my camera is at work, but I found this pic of a strut. The rubber ring sits here, under the spring. I checked other sites and no lists this part.
Aaron Cox |
Aug 25 2004, 01:13 PM
dude..my konis came with bump stops... and also... paragon sells em for cheap too.
Lo-Fi Version | Time is now: 21st May 2024 - 07:29 AM |
