ruddyboys
Aug 25 2004, 10:01 AM
I was under the car yesterday and noticed some dried out pieces of pinkish rubber. It seems to be comming from under the coil spring were it sits on the strut. The strut is black and says Blistein. The strut and coil both seem fine, the rubber could have dried out from 8 years sitting outside, can I get a replacement?
d7n7master
Aug 25 2004, 10:04 AM
Pink Rubber Thing???
Go to any pharmacy and ask for a c-o-n-d-o-m
datapace
Aug 25 2004, 10:13 AM
Probably the remnants of a bump stop. They are thick chunks of rubber that fit over the shock/strut shaft to prevent damage to the shock and chassis during extreme compression.
Sort of like a "last resort". They should be avaliable separately although I think they come with new inserts when you get them.
-datapace
Aug 25 2004, 11:40 AM
QUOTE(d7n7master @ Aug 25 2004, 09:04 AM)
Cap'n Krusty
Aug 25 2004, 11:47 AM
IME, the bump stops don't come with the new inserts, and you REALLY need them. Wait 'til you hear what they cost .................................................... The Cap'n
HarveyH
Aug 25 2004, 11:51 AM
Just did the bump stops about $50. each for a piece of molded rubber with a flat washer fixed to the end... Ah fine German craftsmanship.
Harvey
balljoint
Aug 25 2004, 12:14 PM
I checked out the price on those things too. $65.00 and only at the dealer, I decided that they probably wouldn't fit on the new replacement rear shocks so I left them off.
Very brittle crumbly pink rubber.
ruddyboys
Aug 25 2004, 12:46 PM
Of course my camera is at work, but I found this pic of a strut. The rubber ring sits here, under the spring. I checked other sites and no lists this part.
Aaron Cox
Aug 25 2004, 01:13 PM
dude..my konis came with bump stops... and also... paragon sells em for cheap too.
