6 conversion, Oil tank installation |
bcheney |
Jan 6 2012, 11:48 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Are these bushings nececessary? They are two pieced. I am having issues with clearance of the oil line that comes out of the bottom of the Porsche OEM oil tank when I use these. Line is too close the the bottom edge of the rear fender just above the rockers.
carr914 |
Jan 6 2012, 11:53 AM
Racer from Birth Group: Members Posts: 118,670 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Brian pretty sure they are necessary to space the tank away from the engine wall.
And (IMG:style_emoticons/default/WTF.gif) my cousin didn't pay a visit to tweek you kneecaps? |
rgalla9146 |
Jan 6 2012, 12:18 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Brian pretty sure they are necessary to space the tank away from the engine wall. And (IMG:style_emoticons/default/WTF.gif) my cousin didn't pay a visit to tweek you kneecaps? Just to be sure.... you have one against the tank and one inside the engine comp. then the big flat washer under the nut right ? |
ClayPerrine |
Jan 6 2012, 12:39 PM
Life's been good to me so far..... Group: Admin Posts: 15,468 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Brian pretty sure they are necessary to space the tank away from the engine wall. And (IMG:style_emoticons/default/WTF.gif) my cousin didn't pay a visit to tweek you kneecaps? Just to be sure.... you have one against the tank and one inside the engine comp. then the big flat washer under the nut right ? Yes. And make sure you install the line before you put the tank in. Otherwise you can't get to the line to tighten it up. Also be careful lining up the oil filter console. It's easy to get it misaligned, and if you do, the engine will be starved for oil. |
Jan 6 2012, 12:41 PM
Your going to have to isolate the tank from the body with the bushings. They are stock.
bcheney |
Brian pretty sure they are necessary to space the tank away from the engine wall. And (IMG:style_emoticons/default/WTF.gif) my cousin didn't pay a visit to tweek you kneecaps? Which half of the bushing goes on the inside of the engine bay? |
bcheney |
Jan 6 2012, 01:24 PM
OK...I figured out the problem...I wasn't paying close enough attention to the bushings and the stampings on the coachwork. The slim half of the bushing goes on the fender well side and the thicker one goes in the engine compartment side. I will post pics later so you can see what I'm talking about. Thanks everyone!
Lo-Fi Version | Time is now: 18th May 2024 - 04:25 AM |
