QUOTE(rgalla9146 @ Jan 6 2012, 12:18 PM)
QUOTE(carr914 @ Jan 6 2012, 09:53 AM)
Brian pretty sure they are necessary to space the tank away from the engine wall.
And
my cousin didn't pay a visit to tweek you kneecaps?
Just to be sure.... you have one against the tank and one inside the engine comp. then the big flat washer under the nut right ?
Yes. And make sure you install the line before you put the tank in. Otherwise you can't get to the line to tighten it up.
Also be careful lining up the oil filter console. It's easy to get it misaligned, and if you do, the engine will be starved for oil.
