where did they go, lost 4th and 5th gear |
bernbomb914 |
Aug 25 2004, 12:54 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
finally got to drive the car after way too long. new engine, 2270, new seats, new synchros, new wheels, ATS and tires,Nittos, but somewere I lost 4th and 5th gear put in a rennshift shifter also. so what happened? It shift into those gears but it is like I am in nuteral.
Bernie |
brant |
Aug 25 2004, 12:59 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I'm guessing side to side adjustment in your shift linkage...
its underneath the shifter, yours is not allowing the shifter plane to adjust over far enough... I think there is a tech article somewhere... brant |
Cap'n Krusty |
Aug 25 2004, 01:02 PM
Might want to check the conical linkage bolts under the car.................................. The Cap'n
DonTraver |
Aug 25 2004, 01:03 PM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
That happened to me. Check that all the set screws on the shift linkage joints are tight (shift knukle at firewall and the at the transmission end of the linkage. Mine backed out about 1 turn, lost 4th & 5th. I locktited them back in with locktite blue. No problems since then.
Aaron Cox |
Aug 25 2004, 01:07 PM
haynes has a procedure that describes this....
acces hole in center tunnel, rotate the tunnel shift rod and retightten the screw. makes it all better (IMG:style_emoticons/default/smile.gif) |
bernbomb914 |
Aug 25 2004, 01:48 PM
Thanks for all the information. That is why this forum rocks.
Bernie |
Joe Bob |
Aug 25 2004, 03:12 PM
Sounds like ya slipped a spline...but we already knew that... (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 04:27 PM |
